Old 08-27-2023, 09:35 AM   #1
bobsmanstuff
bobsmanstuff's Avatar
Default Alternator
I have an 53 customline with a 6 volt generator. Thinking of switching to an alternator. Whats all involved? Do I have to change pulleys or anything. Thanks
bobsmanstuff is offline   Reply With Quote
Old 08-27-2023, 09:45 AM   #2
38 coupe
38 coupe's Avatar
Default Re: Alternator
Assuming you have a V8 based on the picture in your profile, you can get an alternator that directly bolts onto your engine, link here: https://www.speedwaymotors.com/Power...Volt,7402.html
If you go with an alternator you need to move a wire at the regulator. You can keep the stock wiring harness (hopefully an amazing condition original or a new reproduction harness).
I have to ask why you want to ditch the generator?
Old 08-27-2023, 10:33 AM   #3
bobsmanstuff
I thought updating it would be more dependable.
Old 08-27-2023, 10:58 AM   #4
19Fordy
19Fordy's Avatar
In the event of a 6V alternator failure, will it be easier to repair "on the road" than a 6V generator? Probably not.
Better off to stay with your 6V if it's working properly. Carry a spare in your trunk.
Old 08-27-2023, 11:18 AM   #5
bobsmanstuff
Thanks Guys for the advice.
Old 08-27-2023, 03:45 PM   #6
Charlie Stephens
Have the generator rebuilt by a good shop and it should last for 100K miles without problems. I assume here you are not running a lot of stuff that requires high wattage.
Charlie Stephens
Old 08-27-2023, 05:36 PM   #7
bobsmanstuff
No I'm not. I'll probably stick with the generator.
Thanks everyone
Old 08-27-2023, 06:26 PM   #8
34fordy
34fordy's Avatar
I had a fellow in Laramie WY rebuild mine. He has a lifetime of experience and his workmanship is unbeatable. [email protected]
34fordy is offline   Reply With Quote
Old 08-28-2023, 10:18 AM   #9
1931 flamingo
1931 flamingo's Avatar
My gen is at the shop again. He said to stay away from the gen looking alternators. FWIW
Paul in CT
Old 08-28-2023, 10:42 AM   #10
38bill
38bill's Avatar
I see your up in Mora. There is a great shop in St Cloud that has been around for years and years if you need help with your generator.
http://www.redsautoelectric.com/
38bill is offline   Reply With Quote
