Old 08-02-2023, 11:00 AM   #1
m610
m610's Avatar
Default Battery for a '36
I'm having trouble finding a battery to fit in the allotted space in our 36 Ford. The space available in front of the driver is about 7.5" tall, and we can't find a battery under 8.5" tall. Are suitable batteries, ones that fit, available, and if not, what do people do, relocate the battery to the trunk?
Mike
m610 is offline   Reply With Quote
Old 08-02-2023, 11:03 AM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: Battery for a '36
Mike
If authenticity does not matter to you, I'd strongly suggest you get a red top Optima. Not much money, lasts for years upon years and has about 150% CCA of a regular acid battery. The Optima can be installed safely at an angle in your stock battery tray.
Pretty easy to rig up a hold down system.
I have done this numerous times in '34 through '36 Fords.
Old 08-02-2023, 01:02 PM   #3
KiWinUS
KiWinUS's Avatar
Kube is spot on. Follow his lead.
KiWinUS is online now   Reply With Quote
Old 08-02-2023, 02:12 PM   #4
TJ
TJ's Avatar
X3 on the Optima.
Old 08-02-2023, 05:50 PM   #5
uncle buck
uncle buck's Avatar
You should have no problem getting an Optima thru your local NAPA store. The Sacramento NAPA Distribution Center has 33 of them. The Optima is taller than your original but easily will fit. Some people will build a simple battery drop and some will mount it on its side , which is ok to do. Part # N996VRED.
uncle buck is online now   Reply With Quote
Old 08-03-2023, 02:22 AM   #6
m610
m610's Avatar
Thanks. We've got the optima. It looks like we could get it to fit if we lean it forward, but it will be exposed to the elements. Does anyone have photos of the hold-downs you used?
Old 08-03-2023, 04:56 AM   #7
KiWinUS
KiWinUS's Avatar
I just used a rubber bungee 16 years.
Old 08-03-2023, 08:52 AM   #8
JM 35 Sedan
JM 35 Sedan's Avatar
This was my solution some years ago....still working well with a 10+ years old Optima 6v red top.
https://www.fordbarn.com/forum/showthread.php?t=320541
John
Old 08-03-2023, 10:47 AM   #9
Daveyjonez
Has anyone had any issues running an Optima with a Generator (Charging Issues??)
Daveyjonez is offline   Reply With Quote
Old 08-03-2023, 11:03 AM   #10
JM 35 Sedan
I have an Optima 6V red top battery, a generator, and a fun project/product regulator. All works well.
Also, I have 3 working 6V Optima red tops in my old cars, and a 12V Optima yellow/yellow top in a 2001 GMC 3/4 Ton pickup truck. The oldest 6V red top was purchased ~ 2007. The 12V yellow was purchased in 2015. All still working.
John
Old 08-03-2023, 11:34 AM   #11
tubman
tubman's Avatar
I've had Optima batteries with a stock generator/regulator setup in my '51 since the early '90's (I'm on my third Optima). Never had a problem.
Old 08-03-2023, 11:45 AM   #12
Daveyjonez
Thanks for the input guys
