Old 07-18-2023, 05:47 PM   #1
CWells
Default Using epoxy resin on a radiator lower tank
Has anyone used Epoxy Resin or other adhesive to repair a hole in the upper or lower tank of a flathead radiator rather than soldering the repair? If so, how did it work? I have a hole in the lower tank of my 36 radiator where a petcock once was and would like to patch it with a piece of brass sheet. Curtis Wells
CWells is offline   Reply With Quote
Old 07-18-2023, 06:58 PM   #2
Karl
Karl's Avatar
Default Re: Using epoxy resin on a radiator lower tank
I've used epoxy resin to repair a broken dental syringe. I reattached the handle with it . We autoclave after use each time to 130C and has held together for the last 5 years. So will probably withstand the heat but solder is so easy ,quick and proven so maybe better to go straight to that
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 07-18-2023, 09:33 PM   #3
1948F-1Pickup
1948F-1Pickup's Avatar
I'd be concerned about the heat with the epoxy.....
1948F-1Pickup is offline   Reply With Quote
Old 07-18-2023, 09:48 PM   #4
pistonbroke
I have had good luck using J B weld on many radiators with holes or slit seams and corroded tubes. Tim
Old 07-19-2023, 12:06 AM   #5
ford38v8
ford38v8's Avatar
If it got as hot as Karl's 130C, I'd be more concerned about the engine.
Alan
Old 07-19-2023, 08:23 AM   #6
19Fordy
19Fordy's Avatar
Under pressure, the top and bottom tank will flex and the Epoxy " fix" will leak.
However, you could give it a try and see what happens. Just keep your eye on the temp. gauge.
19Fordy is online now   Reply With Quote
Old 07-19-2023, 09:14 AM   #7
tubman
tubman's Avatar
All I know is thay have made astonding advances in epoxies and adhesives over the last several years. Think about the body panel adhesives currently available.
Old 07-19-2023, 09:48 AM   #8
woodiewagon46
Well, not a brass radiator tank, but along the same lines. My son had an Isuzu Rodeo and had a cracked plastic radiator top tank. He used JB Weld and it lasted four years until he sold the car. Might still be good for all we know. What do you have to loose?
woodiewagon46 is offline   Reply With Quote
Old 07-19-2023, 12:08 PM   #9
Tony, NY
The 2 part epoxy stick. Have had great results with it. JB weld and Gorilla glue are a couple makers.https://www.amazon.com/Gorilla-42425...250399734&th=1
Tony, NY is offline   Reply With Quote
Old 07-19-2023, 02:07 PM   #10
big job
big job's Avatar
On a Model T the overflow tube is on the bottom of the top tank and fell out losing all the coolant (on the) road so I stuffed wooden matches in the hole got some water and made it home. As we all know the T,s run almost boiling but I epoxied the two part 5 min epoxy and that was like 5 yrs ago. So it does work..
big job is offline   Reply With Quote
Old 07-19-2023, 02:14 PM   #11
RalphG
RalphG's Avatar
I have patched a pinhole leak in radiator cores and top tank with JB weld and had satisfactory results.
RalphG is offline   Reply With Quote
Old 07-19-2023, 08:27 PM   #12
GB SISSON
GB SISSON's Avatar
I too have had good luck with JB weld. Mine was on the core of an aluminum radiator that contacted the fan. Ugly, but after some big loads up my hill I poked it with a steel pick and found it to be quite solid while hot. Has never leaked.
Old 07-19-2023, 08:56 PM   #13
drolston
drolston's Avatar
I had a weeping along the top tank edges and painted on some of the liquid FlexSeal. You know, the loud Patch, Seal and Repair guy on TV. It can stand the heat and is flexible. It has held up for four years with a 4 lb pressure cap.
Old 07-20-2023, 07:14 AM   #14
corvette8n
corvette8n's Avatar
I would try soldering it. My shop teacher alway said “remember it has to be physically and chemically clean before you solder”. (Wire brush area and flux)
