Old 06-22-2023, 06:40 PM   #1
42horsepower
Default Shocks - reproduction vs. rebuilt
Hello all! I'm nearing the end of a restoration project on a '29 pickup. I need to buy shocks (it didn't come with any, so can't rebuild). I would appreciate any recommendations on reproductions vs. rebuilds and sourcing. All the other threads say Stipes. I haven't called them yet, but it sounds like the wait time would probably be a deal breaker for me. It's a family heirloom and the family is eager to drive it while the weather is nice, so I do need something that will be shipped soon. Thanks!
42horsepower is offline   Reply With Quote
Old 06-22-2023, 07:01 PM   #2
JayJay
Default Re: Shocks - reproduction vs. rebuilt
I’ve been waiting over a year for shocks ordered from Stripes, and now they won’t even return my messages asking for projected delivery. Brentwood Bob on this forum rebuilds shocks, suggest you contact him.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 06-22-2023, 07:07 PM   #3
Brentwood Bob
There is a guy here that has several original equipment (OEM) rebuilt sets ready to ship today. Cost will be comparable to Stipes.
He also has OEM shock arms and tubular links.
If you contact him, mention your cars manufacture date, so there is a correct matchup.
PM me.
Pictures in the for sale section listing.
Ps: thanks, JayJay.
Brentwood Bob is online now   Reply With Quote
Old 06-22-2023, 07:29 PM   #4
351cmach
I used a set of Rotoshim for my car. The car rides amazing. They look like originals but are designed with new technology. Well worth the money. https://rotoshim.com/products-1/ols/...s-ford-model-a
351cmach is offline   Reply With Quote
Old 06-22-2023, 09:28 PM   #5
California Travieso
Send a message via Yahoo to California Travieso
I noticed they are on back order. I wonder what the wait time is?
Did you use the Model A arms and other hardware? A picture of your application would help.
David Serrano
California Travieso is offline   Reply With Quote
Old 06-22-2023, 11:27 PM   #6
updraught
updraught's Avatar
Looks like it uses a shim stack like a modern shock, with no adjustment. So, I guess they are tuned at the factory for each body style/weight?
updraught is offline   Reply With Quote
Old 06-23-2023, 06:00 AM   #7
divcoone
divcoone's Avatar
Call Brattons and see what they have to offer.
divcoone is offline   Reply With Quote
Old 06-23-2023, 02:15 PM   #8
42horsepower
Thanks everyone!
Bob - Thanks, I'll message you.
I was wondering if anyone has used the Bratton's reproductions or if folks like rebuilt better. In addition to performance, I'm curious about maintenance and oil leaks. Thanks!
Old 06-23-2023, 02:22 PM   #9
42horsepower
PM me.
Ps: thanks, JayJay.
Hey Bob, I can't PM you because I'm too new to the forums. Apparently I need to post several more times!
Old 06-23-2023, 02:42 PM   #10
LeonardS
There is a “Test” forum at the bottom of the list of forums. Just go there and post some junk messages…..Hello, testing, etc.
LeonardS is offline   Reply With Quote
Old 06-23-2023, 03:00 PM   #11
Brentwood Bob
Sent you a PM. I am in the mafca roster. 94513.
925-872-3639.
Old 06-24-2023, 01:10 PM   #12
Brentwood Bob
As discussed in previous threads, OEM shocks drop oil. Annual spring prep/ maintenance would be a good time to include checking the shocks, although this is not done. Failure, I think, is from neglect. The nitrile seals for the shaft I use should last years, probably well past the 5 years some replacements give. The driver model a's leave oil, and were designed to do that. Salt is not your cars friend. Nor is dust, mud, gravel roads, wind driven sand, small animals, etc.
I believe the "rebuilt"(disassembled, cleaned, new seals, refilled, assembled, tested for function, sealed, and leak tested), Houdaille shock goes on the car, and will give adequate service for a long time. That's its job, and it will do it well.
Old 06-25-2023, 11:18 AM   #13
stevemclark
stevemclark's Avatar
They were missing on my car and I went with a modern shock kit for a lot less, paint them black. Now I can buy new ones from any part store, some kits to look at.https://www.mikes-afordable.com/product/A18014MOD.html . https://modelastore.com/suspension/s...roduct_id=4833 . http://www.snjparts.com/Model-A-Shoc...8-a-18014.html. MODERN SHOCK & MOUNTING KIT W/ DRILLING REQUIRED .
It's not the destination ,it's the journey .
stevemclark is offline   Reply With Quote
Old 06-25-2023, 03:34 PM   #14
Joe K
Joe K's Avatar
And - the so called "friction" shocks are still available.
https://en.wikipedia.org/wiki/Fricti...shock_absorber
https://www.speedwaymotors.com/Speed...ocks,3799.html
Still in some use among the hot-rod crowd. One can actually "tune" these quite well to get to the "vibration neutral point."
Critical damping is the "sweet spot" (Minimal time to restoration of neutral)
Putting your girlfriend in the passenger seat can screw this up.
That might be where the term "Hop-Rod" came from.
Joe K
Shudda kept the horse.
Old 06-25-2023, 10:04 PM   #15
updraught
updraught's Avatar
Joe K
"The damping rate for frictional dampers has less than ideal behaviour for car suspension. An ideal suspension would offer more damping to greater suspension forces, with less damping at low speeds for a smoother ride. Frictional dampers though had a mostly constant rate. This was even greater when stationary, owing to stiction between stationary plates.[1][10] For larger bumps the damping may even be reduced. This is particularly a problem for fast driving, when repeated high forces may cause the friction plates to heat up and lose their efficiency."
In leaf springs, the diagram looks like coil springs, there is already a fair bit of friction.
Old 06-26-2023, 06:09 AM   #16
Hotrodfil
Hotrodfil's Avatar
I've been using the Rotoshims - I have a set on two cars now. Definitely recommend them. If you tell them your application they can be factory tuned. Each shock is dynamically tested after assembly to make sure they're matched.
Hotrodfil is offline   Reply With Quote
Old 06-26-2023, 11:32 AM   #17
mass A man
mass A man's Avatar
Don't wait to drive the car. Shocks or not, the car will go down the road just fine without them. Your wallet will help you decide which set of shocks you will get, but enjoy the short driving season while you can. The original type shocks are best, as I like originality on the Model A's if possible. If you spring a leak with the less expensive ones, I don't know how one could replace seals in them, but I imagine they could be if they went in them at one point.
mass A man is offline   Reply With Quote
Old 06-26-2023, 02:17 PM   #18
81ls1camaro
I just bought a modern set from Ken Davis Model A if that is what you are looking for. He's probably $100 cheaper than the major vendors, and they all about the same.
http://www.kendavismodela.com/Shocks.html
81ls1camaro is offline   Reply With Quote
Old 06-26-2023, 03:06 PM   #19
LeonardS
He is less expensive, but his kit requires a hole to be drilled through the front axle. I don’t think that sounds like a great idea.
Old 06-26-2023, 03:20 PM   #20
alexiskai
alexiskai's Avatar
Not a great idea in terms of aesthetics, performance, or market value?
