Old 06-17-2023, 02:05 PM   #1
bschulze
Default How can I hold the windshield open, roadster PU
Please help.
When I'm driving my 1928 roadster pick up, the windshield blows closed. The only ventilation is through the side openings.
I can't tighten the top wing nuts enough to hold the wind shield open. Should I try to add swing arms to hold the windshield open?
It does not appear slotted wing arms were originally there on a 1928 roadster pick up .
Thank you.
Bob
bschulze is offline   Reply With Quote
Old 06-17-2023, 02:24 PM   #2
MAG
MAG's Avatar
Default Re: How can I hold the windshield open, roadster PU
The problem is the cup washer in the pivot post. Repro cup washers will not hold the windshield open due to its shape. The shape does not correspond to that of the round portion of the post. You can try to reshape it. Best bet is find a original cup washer.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 06-17-2023, 02:49 PM   #3
Tom Endy
Tom Endy's Avatar
Years ago, I had a 28 Roadster and had the same problem. I went to Home Depot and purchased a length of wooden dowl about an inch in diameter and two rubber boots. I cut the dowl about 4 or 5 inches long, put the boots on the ends and used it to hold the windshield open.
Tom Endy
Old 06-17-2023, 05:49 PM   #4
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by Tom Endy View Post
Years ago, I had a 28 Roadster and had the same problem. I went to Home Depot and purchased a length of wooden dowl about an inch in diameter and two rubber boots. I cut the dowel about 4 or 5 inches long, put the boots on the ends and used it to hold the windshield open...
Tom Endy
I like it!! Simple and easy.
Old 06-17-2023, 07:11 PM   #5
Keith True
Keith True's Avatar
I have the same thing in my 30 open pickup.I'm not about to try and dig out the welded in cups out of the stanchions,so I made a stick I carry to hold it out when I want it open.I had the same thing on a 28 open cab I had.I have a 28 phaeton now,and I found a short stick under the seat.I suspect that was made for the same thing.
Old 06-18-2023, 12:45 PM   #6
1931 flamingo
1931 flamingo's Avatar
I like tom Endy did but I used a wood paint stirrer cut to length on my TuDor.
Paul in CT
Old 06-18-2023, 06:26 PM   #7
frank55a
Keep it simple. I just fold a rag and stick it in between the the windshield and rail at the bottom about in the middle of the windshield. No chance of scratching the paint.
frank55a is offline   Reply With Quote
Old 06-18-2023, 10:55 PM   #8
henry's 31
Hi Tom:
Do you happen to have a photo of what you did?
Thanks
Henry' s 31
henry's 31 is online now   Reply With Quote
