Old 06-14-2023, 02:33 PM   #1
JimG1127
JimG1127's Avatar
Default Thermostat
Thermostats on As are installed in the upper radiator hose? Thanks.
JimG1127 is offline   Reply With Quote
Old 06-14-2023, 02:47 PM   #2
Rob Doe
Default Re: Thermostat
Not all, Vintage Precision has a really nice tstat setup. Check it out.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 06-14-2023, 03:00 PM   #3
JimG1127
JimG1127's Avatar
That does look good. But I've already got the water outlet gooseneck tapped for the water temp sensor.
Old 06-14-2023, 03:29 PM   #4
alexiskai
alexiskai's Avatar
Yes, upper hose. Often you will find that the thermostat migrates to the top of the hose, which will alter its behavior. People use various strategies to mitigate this. You can cut a section of lower hose, which is narrower, and put it in the upper hose above the thermostat. You can also just add a hose clamp, but some folks consider this unsightly, hence the lower hose workaround.
Old 06-14-2023, 04:35 PM   #5
Ernie Vitucci
Ernie Vitucci's Avatar
Good afternoon...We also use the Vintage Precison unit. It is the best of the possibilites on the maket in my view. Ernie in Arizona
Old 06-14-2023, 04:43 PM   #6
Big hammer
I went to the hardware store and found a couple plastic pipe fittings that fit snugly, the two in tandem hold the thermostat at the water outlet neck.
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 06-14-2023, 07:18 PM   #7
JimG1127
JimG1127's Avatar
If I put in a section of lower hose into the upper hose to hold the thermostat in place can it be a short section or should it be the length of the upper hose? There must be a fairly strong force of water going through.
Some people say drill a couple of small house in the thermostat so that there is always some coolant getting through. Should I?
I'm also putting in a new Brassworks radiator. I will flush out the block first. Some folks say stretch an old sock over the upper radiator water inlet before attaching the hose to prevent crude from getting into the radiator. Is this a good idea?
Old 06-14-2023, 07:42 PM   #8
alexiskai
alexiskai's Avatar
1. 1-2” of lower hose is probably fine.
2. Current thermostats come with the holes already drilled.
3. If you’re serious about protecting the radiator, I suggest a Gano coolant filter, not a sock.
Old 06-14-2023, 07:47 PM   #9
Synchro909
Synchro909's Avatar
Is there a market for a Gano Filter/Thermostat combined device? I can't see that it would be difficult but setup costs might be too high.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 06-14-2023, 07:50 PM   #10
JimG1127
JimG1127's Avatar
I took a look at the Gano coolant filter. What a great idea! Never knew about it. I will get one. Thanks!
Old 06-14-2023, 10:51 PM   #11
Wello
Wello's Avatar
After years of chasing the thermostat around the upper hose I made this fitting. It simply fits in the water outlet neck and is held in place with JB Weld. So far it has worked quite well.
Wello is offline   Reply With Quote
Old 06-15-2023, 12:20 AM   #12
stickshift
stickshift's Avatar
I used a black zip-tie above the thermostat. So far, keeping it in place and it blends in with the black hose. It's not too noticeable, but it's a truck and I'm not concerned about points.
Stickshift
1915 Model T touring
1931 Ford Model AA Flatbed
stickshift is offline   Reply With Quote
Old 06-15-2023, 04:33 AM   #13
JayJay
I use the Vintage Precision unit and could not be happier. A bit pricey, yes, but a first-class device. The sensor on my water temp gage was long so I had to add in VP’s extender fitting, I think that should be part of the normal package, not an add-on. I use the fitting in the upper radiator hose for my coolant heater.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 06-15-2023, 04:43 AM   #14
Werner
Werner's Avatar
Originally Posted by Wello View Post
... and is held in place with JB Weld. ...
Attachment 518558
Wello,
It has been my experience that glycol based antifreeze will attack the two component adhesive.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 06-15-2023, 11:55 AM   #15
JimG1127
JimG1127's Avatar
Lots of great info! Ford Barn has been a real asset. Thanks everyone!
Old 06-15-2023, 03:04 PM   #16
JayJay
Didn’t think to mention it, but you likely want your temp sensor before (below) the thermostat. If you had it above you’d never know if the thermostat stuck closed. Although in my experience I’ve had them stick open, but never had one stick closed.
JayJay
Old 06-15-2023, 05:24 PM   #17
Gene F
Gene F's Avatar
Can I ask a question. Who cares if it ends up at the top end of the hose, up against the radiator neck. I mean why do we care? It still will slow down the water.
Old 06-15-2023, 05:38 PM   #18
ModelA29
ModelA29's Avatar
It doesn't open until the hot water gets to it. Close to the engine it will open sooner. The engine will be at a higher temp before the hot water migrates to the top of the hose since water won't be flowing with it closed.
The small holes in the thermostat is to let air out of the system when you refill it.
ModelA29 is offline   Reply With Quote
Old 06-15-2023, 07:30 PM   #19
Herb Concord Ca
I have VP thermostat housings on both my Model A's for years, couldn't be happier. Best on the market.
Herb Concord Ca is offline   Reply With Quote
Old 06-15-2023, 07:57 PM   #20
Y-Blockhead
Y-Blockhead's Avatar
You need a plug in the side your distributor, helps keep dirt and moisture out
File Type: jpg Screen Shot 2023-06-15 at 5.50.15 PM.jpg (6.0 KB, 534 views)
