What lubricant works besst in my 1936 Ford steering box?
Thanks |
Super Moderator
In my opinion, John Deere corn head grease. About $7 a tube.
Thanks
How many tubes does it take to fillan empty Box? |
Another vote for JD corn head grease. My memory isn't very good but I think I used 1 tube when I filled the 37 Hudson box in my 32 pickup.
You need a liquid that will get past the sector and into the two bearings. My suggestion is 140W Gear oil.
Corn Head Grease is a high quality multi-purpose, semi-fluid type grease available in an NLGI #0 grade. Although primarily applied in corn head lubrication, this product can be recommended for many applications in agriculture, automotive, construction and industrial environments. Check out this YouTube Video below: https://youtu.be/7zNhli-J0Gk
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 04-28-2023 at 09:43 PM. Reason: Added YouTube Video on JDCH Grease |
How do you get the corn head grease in the steering box? Will it pour or do you have to use a grease gun?
I used a grease gun with the tip removed from the pipe.
Super Moderator
I had installed a grease fitting to an extra filler cap. Install that modified cap, pack the steering gear box and replace with the stock cap. That way, I know the box is full.
Thanks Again
IF it leaks fix it use 140 gear oil.
I removed the box and shoved the cornhead grease in by hand. One tube did it.
https://www.fordbarn.com/forum/attac...1&d=1682701386 |
#13 |
John Deere corn head grease is "00" grease. If you can't find Deere brand most lubricant companies sell "00" grease.
#14 | |
#15 |
Problem with JD Corn Grease, is, it will settle, even though it gets hot from the manifold, nd does not lube the top bearing, which will thus wear out.
Steve in Denver |
#16 |
Actually, corn head grease, whether in a green tube or any other color tube is “0”. Cotton picker spindle grease is “00”, a pourable grease.
I dig coal, which provides motivation for EVs. |
#17 |
Super Moderator
Really? I'd better run out and check my farming equipment right now.
#18 |
Steve in Denver, Have you personally experienced this top bearing failure in the steering box of your early Ford V-8 when using JD Corn Head Grease?
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 04-30-2023 at 01:13 PM. |
#19 |
Cap with the zerk seems like the best way to go. Simple and cheap and the top bearing can't escape the rising cornhead tide.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
#20 |
