Old 04-08-2023, 02:00 PM   #1
dono50
dono50's Avatar
Send a message via MSN to dono50
Arrow Converting heater to 12volts
Converting a 46 Ford coupe.Tried to use a heater motor from NAPA # 655-1020 (61-63 Chevy truck)but about 1/2-3/4 inches too long.
Any suggestions regarding what motor to use or other procedures would be appreciated….thanks
dono50 is offline   Reply With Quote
Old 04-08-2023, 02:19 PM   #2
TJ
TJ's Avatar
Default Re: Converting heater to 12volts
What was too long? the body of the motor or the shaft? If it was the shaft you can cut it to make it shorter.
Old 04-08-2023, 02:26 PM   #3
dono50
dono50's Avatar
The body of the motor, I did cut the shaft too.
Old 04-08-2023, 07:00 PM   #4
50fordcoupeman
50fordcoupeman's Avatar
I ran my avatar 6v heater on 12v for many years with no problems.
50fordcoupeman is offline   Reply With Quote
Old 04-08-2023, 07:36 PM   #5
johndee138
johndee138's Avatar
I found a 12v computer fan that fit my heater. Cheap and works good.
johndee138 is offline   Reply With Quote
Old 04-09-2023, 03:26 AM   #6
51 MERC-CT
51 MERC-CT's Avatar
Never changed my 6 volt 2 speed heater motor in my '51 Merc.
Has been running on 12 volts as needed for well over 20 years.
Only difference is it runs faster just like the starter motor.
Old 04-09-2023, 03:35 AM   #7
dono50
dono50's Avatar
Thanks for the advice, I’m going to reinstall my 6 volt motor.
Old 04-09-2023, 05:15 AM   #8
flathead48
Hey pal, you need A/C down there not heater, Happy Easter
flathead48 is offline   Reply With Quote
Old 04-09-2023, 07:55 AM   #9
custom_lettering
I use one these they work great.
https://vintageautogarage.com/heater...00-watts-hr02/
custom_lettering is offline   Reply With Quote
Old 04-09-2023, 08:15 PM   #10
dono50
dono50's Avatar
You are right RB. BTW, that trunk arm fix worked like a charm. Regards
Old 04-12-2023, 11:08 PM   #11
dono50
dono50's Avatar
Originally Posted by custom_lettering View Post
Thanks, sounds great…
Old 04-13-2023, 08:49 AM   #12
woodiewagon46
dono, I used a motor from Dennis Carpenter PN B6A-18527-B in my '46 Ford but it was over $100. About a month ago someone also asked about a 12V motor and someone posted a suggestion for almost the same motor for half the price. If you search this site you might be able to track down that post.
woodiewagon46 is offline   Reply With Quote
