There is a hood rod pivot point on top of a radiator shell. Can anyone advise how the pivot point for the hood rod is secured to the radiator shell??
Is it soldered, or spot welded, or???? Trying to get one off a 31' shell Thanks!!
Bob from Northport Northport, Michigan |
Mine just slides out, is yours rusted?, penetrating oil could be your friend
I just looked at my 31 shell, it sure looks like a rivet to me. I can't see the underside, but the top sure looks like a rivet head.
It looks like a rivet to me also. But i drilled it out on both sides and it will not move.
Bob from Northport on my 1930 a coupe they were small rivets, drilled and punched out,also had grill off
riveted
This should answer your question, there are rivets.
Bob Bidonde |
Thanks for the help. It was riveted on.
Bob from Northport Northport, Michigan Last edited by Bob from Northport; 08-07-2023 at 06:00 PM. |
