Old 02-22-2023, 03:59 PM   #1
Jason M.
Jason M.'s Avatar
Default Dan Brusgard Steering Mast Jacket bearing Availability
May I ask if anyone is aware of the Dan Brusgard "Needle Bearing" steering column mast jacket kits are still available? I've tried contacting him via email twice now and cannot seem to locate the kit on ebay?
I'd buy a kit anywhere if it where available. Thank You
Jason M. is offline   Reply With Quote
Old 02-22-2023, 04:16 PM   #2
TJ
TJ's Avatar
Default Re: Dan Brusgard Steering Mast Jacket bearing Availability
If you cannot locate him or one of his kits there is an alternative. Many of the V-8 parts vendors carry a kit which includes a bearing, a sleeve, and a spring that will work just fine on an early column and shaft. I know that C and G carries the kit and I'm sure others have it too.
Old 02-22-2023, 05:01 PM   #3
Kens 36
Kens 36's Avatar
Jason,
Send you a private message.
Ken
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
Old 02-24-2023, 09:04 PM   #4
38 coupe
38 coupe's Avatar
Third Gen Auto sells a bearing for the steering column that looks better to me than the spring loaded plastic option. Disclaimer, I have yet to install the one I ordered.
https://thirdgenauto.com/product/193...olumn-bearing/
Old 02-24-2023, 09:35 PM   #5
A bones
A bones's Avatar
IMHO needle bearings seem to be inefficient in that task.
I would much rather rely on the ball bearing application many of us use.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 02-25-2023, 11:48 AM   #6
cas3
Wheel barrow wheel bearing works good. At your local hardware store
cas3 is online now   Reply With Quote
Old 02-26-2023, 08:24 AM   #7
38 coupe
38 coupe's Avatar
I installed a Dan Brusgard needle bearing kit in the 37 sedan that my father and I jointly owned. I liked the steering improvement so much I was pondering attempting to take the needle bearing setup out of the car before I sold it to a friend (I didn't, my friend got the improved steering).
Old 02-26-2023, 09:37 AM   #8
Bill OH
Wheel barrow bearing x2.
Bill OH is offline   Reply With Quote
Old 02-26-2023, 10:05 AM   #9
Steve/IL
Steve/IL's Avatar
I believe that these hardware store bearings have a small flange on one end of the O.D.
I've got the old car disease. Thankfully there's no cure!
Steve/IL is offline   Reply With Quote
Old 02-26-2023, 07:06 PM   #10
Oldcarbearings
Location: North Warrandyte, Melbourne,Victoria, Australia
Steve/IL,
You're correct the hardware store bearings indeed have a flange,
We in the bearing industry call them "unground" bearings,
99.9% are made in china!,
I'm not aware of nor have ever seen in over 40yrs in the industry euro/usa/uk even jap made versions,
They're used in brick cutting machines, golf buggys , hand trolleys, a multitude /numerous a/various applications, they're poorly made &don't last very long,
I end up convincing customers to buy sealed unflanged versions more $ yes but far&way outlast the flanged versions being fully sealed both sides or metal sheilded.
Oldcarbearings is offline   Reply With Quote
