Old 02-01-2023, 04:35 PM   #1
Lincolnville
Default Lead in the seams - 1932
Did Ford put lead in the seams to hid them? About every time I try and fix a seam / or weld on seam I run into lead...
Lincolnville is offline   Reply With Quote
Old 02-01-2023, 04:54 PM   #2
mcgarrett
Default Re: Lead in the seams - 1932
Yes, depending on year of mfg. What year are we talking about?
mcgarrett is online now   Reply With Quote
Old 02-01-2023, 04:55 PM   #3
Lincolnville
1932 Ford Cabriolet.
Old 02-01-2023, 05:08 PM   #4
mcgarrett
Sorry, you stated 1932 and I missed it.
I'm not aware of lead being used on seams of any '32 Fords, but I stand to be corrected by more experienced '32 owners.
Old 02-01-2023, 05:26 PM   #5
51 MERC-CT
51 MERC-CT's Avatar
Virtually all brand manufacturers used welded/spot welded seams to connect body panels together. These were then filled, using lead filler to hide them.
Old 02-01-2023, 06:01 PM   #6
DavidG
DavidG's Avatar
There are lots of seams on '32 bodies and they are covered up with lead to eliminate imperfections in the joint. On a '32 cabriolet, Ford did not create a one-piece pair of quarter panels and upper back panel, nor were the cowl top and cowl sides formed in one piece.
Old 02-02-2023, 01:14 PM   #7
Bored&Stroked
Bored&Stroked's Avatar
Just think of lead as "body filler" back in this era. Given the number of seams in these bodies, there would always be slight imperfections/waves that needed to be filled and filed smooth prior to primer and paint.
