Old 01-31-2023, 02:20 PM   #1
AnthonyG
AnthonyG's Avatar
Default 35 ford juice brake conversion
Hi all & Happy New Year! I've been taking my time on the hydraulic brake conversion as i don't have as much steam @ 73 as i did @ 60 when i got the 35!
Anyway, I'm getting ready to move on to install the '47 Lockheed rear brake assy's & wanted to reverify that I can use my existing mechanical brake rear drums and wheel flanges with the stock '47 Lockheed backing plate assy's. My '35 Stock Drums haven't been cut & look to have minimum miles. I believe previous owner replaced many years ago and didn't put many miles on the car.
I got the 'Early V8 Garage ( Rich ) frame & conversion kit' & 1947 ford master cylinder installed, also new '47 KP's & front Lincoln brakes, all went pretty smooth. I think I'll need to fabricate a remote brake fluid well placed on the firewall as adding fluid under the front seat will be a PIA.
Nomad
AnthonyG is offline   Reply With Quote
Old 01-31-2023, 05:57 PM   #2
PeterC
PeterC's Avatar
Default Re: 35 ford juice brake conversion
Re "I think I'll need to fabricate a remote brake fluid well placed on the firewall as adding fluid under the front seat will be a PIA.[/QUOTE]" ...
Actually I found checking / adding fluid a MC mounted where the battery formally lived work quite well using the existing floor battery hatch. The battery was then relocated to behind the seat on the passenger side.
PeterC is offline   Reply With Quote
Old 01-31-2023, 06:15 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
'35 REAR drums will accommodate 1-3/4" wide Lockheed brake shoes. Actual '35 rear drums have the multiple circumferential ribs as seen in pics BELOW. They also have the raised nibbies to support the '35 spoke wheels. Drums should work just fine.
Remember.... When you install these drums, CLEAN & DRY axle tapers, as well as the tapered hole in hub! Re-tighten the big axle nut after you've driven 50-100 miles.
Keep us updated, please!
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 02-02-2023, 05:53 PM   #4
AnthonyG
AnthonyG's Avatar
Thx Coop & will do w updates!
Nomad
Old 02-02-2023, 06:03 PM   #5
AnthonyG
AnthonyG's Avatar
PeterC, beautiful job on ur frame up resto & brake conversion! Urs is custom & u went to a dual master which is great! Having it in the old battery location is great & far enough in front of the seat to add fluid. My kit from Rich’s Early V8 Garage uses a 1947 single master indexed 90 degrees & mounted under the seat on the frame w sub frame supplied. U literally have to remove the seat & have a hole in the floor to put fluid in. Not gonna do that & is why I’ll b designing a remote well firewall mounted!
Thx for the pic of ur set up & resto work! It is a work of art ! I’ll try to post a pic
File Type: jpeg 044D6471-C911-49E3-991B-7735AA9B9272.jpeg (38.9 KB, 46 views)
Nomad
