Old 12-08-2022, 01:37 PM   #1
jeepguy1948
Default Stromberg/Webber adapter
I’m thinking of trying a Stromberg 97 on my banger. I already have a manifold for a Webber carburetor that I would like to use. Does anybody know of a source for an adapter? I realize that a great many of you could and would make your own but that is not really an option for me
jeepguy1948 is offline   Reply With Quote
Old 12-08-2022, 04:02 PM   #2
CarlG
CarlG's Avatar
Default Re: Stromberg/Webber adapter
I went from a Weber to a Stromberg 97. I went ahead and purchased a new manifold for the 97, then sold my Weber complete as a set.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-08-2022, 07:35 PM   #3
jeepguy1948
Obviously you thought the Stromberg was preferable to the Webber (which I have heard from others as well).
Old 12-08-2022, 09:23 PM   #4
GeneBob
Stromberg to Weber Mani Adapter.jpgJeepGuy,
I still have the adapter I made for trying a Stromberg on my Weber manifold if you are interested. If you cover shipping, you are welcome to try it out.
GeneBob is offline   Reply With Quote
Old 12-08-2022, 09:51 PM   #5
Synchro909
Synchro909's Avatar
I'm finding this conversation about Stromberg 97 vs Weber interesting. I have just fitted a Weber to one of my cars and a copy Weber to another. I'm happy with the results but wonder whether a 97 might have been better.
FWIW, For the copy carburettor, I fabricated a manifold out of 3mm (1/8") sheet to suit.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 12-08-2022, 10:33 PM   #6
updraught
updraught's Avatar
Probably seems better because the Stromberg opens both barrels at once, whereas the Weber would be sequential?
A couple that may be somewhat close, would need some measurements...
https://www.ebay.com.au/itm/27554303...yABEgJ3FvD_BwE
https://www.lakeheaders.com/products...o-4bbl-adapter
https://www.speedwaymotors.com/Late-...apter,808.html
updraught is offline   Reply With Quote
Old 12-09-2022, 10:54 AM   #7
Jordan
Jordan's Avatar
I have had multiples of both on my cars--- I will say I do like the weber better. It just seems to run consistently the same. My strombergs seem to run a little different with each tank of gas.
Cowtown A's
Jordan is offline   Reply With Quote
Old 12-09-2022, 11:02 AM   #8
GeneBob
Jordan,
If your Strombergs are old, you may be fighting vacuum leaks. I chased the tuning of a Stromberg when I put on the supercharger and an air/fuel meter. I ended up buying a new Stromberg and it tuned in much better. Of course, these days, each tank of gas is probably a little different with unknown amounts of alcohol in each tank in the ground.
Old 12-09-2022, 12:14 PM   #9
jeepguy1948
One thing that causes me to lean toward the Stromberg is that it is so much easier to work on and with (for a so so mechanic (me)). There is no doubt that a Webber can be tuned to work better than the Stromberg but you really need to know what you’re doing and probably should have an air/fuel sensor. My understanding is that the Webber will deliver better fuel economy if that is a priority.
Old 12-09-2022, 01:44 PM   #10
CarlG
CarlG's Avatar
I really had no problem with the Weber, it was just that my engine builder (the late Ron Kelley) preferred the Stromberg 97, so that is what I went with. I bought one of the new units that are currently being made in the UK. Ron re-jetted it to suit the Model A.
Alaskan A's
Old 12-09-2022, 10:35 PM   #11
jeepguy1948
Hey Gene, thanks for your kind offer but I think I came up with one locally
Old 12-10-2022, 07:44 AM   #12
1929
My 97
1929 is offline   Reply With Quote
Old 12-11-2022, 05:12 PM   #13
Jordan
Jordan's Avatar
Originally Posted by GeneBob View Post
Attachment 505040
Attachment 505041JeepGuy,
I would be interested in purchasing this as I carry a stromberg as my spare carb and would be a lot easier to throw this on rather than carry a spare manifold and swap that out.
Cowtown A's
Old 12-12-2022, 11:54 AM   #14
Jim Brierley
I made an adapter out of hardwood, I think hardwood isn't necessary but I had some. I adapted a Winfield manifold to a 38/38 Weber, worked just fine, and also acted as an heat insulator for the carb.
Old 12-12-2022, 12:18 PM   #15
jeepguy1948
Great idea Jim! How did you feel about the performance of the Webber as compared maybe to a Stromberg? I know none of your engines are ever close to stock and your Webber is bigger than that typically used on a banger but even so I would be interested to get your opinion
Old 12-12-2022, 03:24 PM   #16
Lawrie
Lawrie's Avatar
One benefit of the 97 is is can easily be made to run with out a fuel pump.
Lawrie
Lawrie is online now   Reply With Quote
Old 12-12-2022, 04:24 PM   #17
Jordan
Jordan's Avatar
Lawrie
How do you do this? I have always had fuel pump issues on one of my cars in particular.
Cowtown A's
Old 12-12-2022, 04:49 PM   #18
Lawrie
Lawrie's Avatar
Have a look at my post from way back, I posted picks ands instructions.
You have to do a little mod on the inlet valve ,mine has been on for about 10 yrs no drama.
Lawrie
Old 12-12-2022, 07:43 PM   #19
walls
https://www.fordbarn.com/forum/showt...loat+valve+mod
Lawrie- you mention opening up the inlet hole.can you expand on that a little? Did you use a certain drill bit?
walls is offline   Reply With Quote
Old 12-13-2022, 02:06 AM   #20
Lawrie
Lawrie's Avatar
Walls, some where I have the drawings I did at the time, I have a big day tomorrow but will see if I can find them ,if not I will be away until 27th so then I will look them out,, or pull the carb off the model a and take some pics. there is more than just drilling out the hole
Lawrie
