I have 9 or 10 V8 blocks here and the majority came to me as bare blocks. The rest I stripped down myself. All are 24 stud blocks. Approximately half are early style, mostly 59ab, the rest 8ba style. As many of you know I live on an island with no machine shop. I would really like to check all these blocks, none of which are more than .040 over. Back story is they came from a neighbor who is a mechanic and owns 5 or 6 'tri-five' chevys and "not a fan of the flatheads". The engines had belonged to his father in law (one of us), but he sold his farm and moved into a small space so off they went. I was told that the FIL had scrapped 13 bad blocks but kept these because they were good builders. I see one visible crack in the whole lot, typical valve to cylinder, and one block with a valve seat peened around the circumference that looks like it was run that way. I wouldn't.
About 5 years ago I used a pressure test kit that was loaned to me by a fellow barner. It was simple and worked well on the one engine I had at the time. Apparently these are no longer offered so I would like to build one. The borrowed one had steel plates to block off heads and pumps. (too much work to build)...My thought is use actual heads with an 1/8" epdm rubber sheet gasket, gutted water pumps with a solid sheet gasket, also rubber. I have probably 30 heads and 20 water pumps kicking around. Pipe plugs and expansion plugs where needed. I even thought the water pump gaskets could be made from inner tubes containing the valve stem. Anybody made a home pressure tester kit? Any and all ideas welcomed as long as I don't have to bother a machine shop....Maybe I will start a seperate thread on home brewed magnaflux afterwards. Thanks!
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) Last edited by GB SISSON; 12-01-2022 at 11:45 PM. |
Gotta ask, so is peening around a valve seat a bad idea? I’ve never done it but I have a Kwik-Way tool for that very purpose. Just curious
#3 | |
Gary,
Probably a stupid idea on my part since I'm not a diagnostics mechanic (I can only wrench and do a bolt in replacement) but years ago I worked running HVAC equipment and natural gas lines. Upon completion of the install we pressure tested the components and looked for leaks using a simple spray bottle with liquid soap mixed up. If it bubbled there was a leak. If not, it was sealed. You could tell right away. If you plugged everything and tested for leaks this way at least you'd know if it was your install or the pressure was exiting elsewhere. Inner tubes to my way of thinking would seal quite well assuming the curvature of the membrane wouldn't interfere under compression. Getting something air tight can be quite a challenge. Give it a try, you're not out much if anything except your time. Tom |
Found 2 post in the archive that speak of making plates.
Head gasket as pattern to cut combustion chamber shape. One flame cut steel plate. Looks bad works good. Plus plate to cover W-pump hole. Other one sawed some thick aluminum plate.
Enjoy yer day. Tom ![]() Hate can't fix what it started. |
I’m thinking inner tube thickness varies too much, and curvature if the tubes would also compromise the seal. A lot of wasted effort trying to make inner tubes to seal if good flat rubber sheeting is available. Time is money even when retired.
Alan |
Old truck tubes are thick and wide. The tubes I took out of my army jeep last year probably weigh 8-10 pounds each, the tire was dated 1952, and I would not be afraid to use them again ! perfect for head gaskets I believe
On the plate itself, you need to be able to easily inspect the ports, chambers and bores for leaks (and spray a soap-based solution and look for bubbles). What this means is that you need access to the ports and bores while pressure testing.
So, take an old head and if you have access to a really good drill press of better yet milling machine, then you can use a good ole' hole saw at slow speeds to bore through a stock head - in the bore areas and valve areas (two cutters) to make a pressure plate. Is it a lot of work . . . sure . . . but unless you want to have a machine shop make you one, there isn't much other choice. Just a thought . . . B&S |
You can do a simple Pass/Fail test just using the heads. Just install some heads so that are known to be good and block off all the water openings. Fill the block with water and pressurize. If the assembly will hold pressure, you are good to go. If it does not, it may be difficult to determine the source of the leak.
#11 | |
#12 | |
#13 |
https://www.speedwaymotors.com/Offen...Kit,25045.html
I bought one of these and it works like a charm! edit: I just noticed they are on backorder! Sorry Last edited by deuce5wndw; 12-02-2022 at 10:27 AM. |
#14 | |
Gotta say that speedway set looks pretty nice with the added plus of viewing of valve pockets. That's about 30 bucks per block when a guy has ten of em! I have two friends on the island that have plasma tables. I don't really understand how they work, except that they work remarkably well. They scan an object (head?) and it goes into the computor, at that point it can be altered, then the thing cuts out your steel plate into whatever is on the program. It is mind boggling seeing this apparatus cut 1" steel plate with no slag and all the cuts are perfectly plumb etc, etc.... I can talk to them. On the hillbilly front, I wonder if my bosch jig saw with a good lenox blade would cut the heads open? I suppose I should start with the solid sheet of rubber under a stock head anb see what I find. I assume I will need to at least put a knife cut through each cylinder location on my rubber gasket....
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
#15 |
I made gaskets from scrap pieces of vinyl flooring. Easier to cut and punch out stud holes compared to rubber sheeting and the cost was zero. This went under a stock head which was magnafluxed separately by the same shop that performed the pressure test. The machinist said the vinyl flooring gasket worked well for the test. Separate gaskets were made from the same material for the water inlet/outlets.
#16 |
Mine was done quite randomly by hand with punch. I can see that the cast iron of the block actually deformed from the blows. Maybe it's fine, but if it turns out not to be, well you get it...
#17 |
Just an idea, but do you think some nicely made wooden block offs would work? Might be up your alley, GB.
#18 |
Excellent thinking Mart !
#19 |
How about using some really thick say 3/4" maybe 1/2" clear plexiglass or some other strong clear plastic. You could use your jigsaw & hole saw. Lexan that is what I was thinking of. Made side windows for my roadster from using this.
#20 |
Some really good ideas flowing in here. I am almost finished with a recent biography of Thomas Edison. He and his 'boys' worked long hours in the lab and constantly bounced ideas off each other. We don't need no stinkin' lab!
With plywood or lexan I could fasten a head down and drill through the stud holes as a template guide. Water pumps too! If the sheet gasket was already in there, all the better....
