I have a chance to take these on a trade, they are being added for boot on a 39 RatRod. Value of $400.00. The motor on the frame is bound up. The one on a stand will turn. I’ve only seen these pictures myself. WhT do you guys see?
#2 | |
![]() Quote:
Not sure where the $400 value came from. That would seem like a pretty subjective conclusion at this point. If it were me, I believe I'd be more interested in determining the condition of those two brake drums. And if that is actually a '39 Ford, that brake & clutch pedal assembly is probably worth at least $100. Coop |
I bought one that turns for 400. and was happy to get it. the frozen one prob 100. but I wouldnt even carry it home.
The heads (EAB) on the 8BA in the frame were used in '52 and '53 pass car 239 production and had the smallest chambers, meaning a higher ompression ratio. Too bad it's stuck.
Sal |
Like V8 says, the brake pedal assembly and front drums and backing plates (if they are 1939) are worth more than the engines (and a lot easier to transport). Buy them for $100 and leave the engines.
Thanks, I’ll take a look at them. So what about the frame? I know it’s hard to tell from pictures
EAB heads are worth something as well. I recently bought an 8ba that was stuck. A 50/50 mix of acetone and ATF and a little bit of patience got it unstuck. A set of used plugs and new oil after draining it and it fired right up. So you never know what you'll get with a flathead.
It got a sway bar and hydraulic brakes . When did they bring in the 5 1/2 x5 ?
In this day and age, 400 bucks idn't much money, and all this "Junk" might be a gold mine, Even if one block is good. Yes, stuck valves are more pron to lock up a flathead , than rusty pistons. are all the plugs in? just can't see much these days.
Grumps. |
I’m going to get them! Thanks for responses
#13 |
We got a RG 85 member who scraps every flathead engine regardless, really burns me up. Never checks anything. Newc
#14 |
If you go for it I will toss in $100 for the EAB heads if they are good. Tim
#15 |
#16 |
If it were me, I would check what the current local scrap price is for say 1800 lbs. That is a good starting place for assigning if the value approaches $400. I have torn apart too many sludge filled rusted, fatally cracked motors to ever do that again as I have a couple of known good blocks. If you are young and like to gamble, go for it! Knowing if they have been sitting outside is an important consideration too. As others pointed out the value there may not be in the engines. Good luck.
#17 |
Frames that are not rusted out where the X members meet the outside rails are something to keep
#18 |
Fill up the carb with oil and let it sit awhile.
#19 |
#20 |
Here is the rat rod I can traded a Harley for I’ve had over 20 years. Getting out of the motorcycle business. I have another 2009 Ultra, will trade for old stuff.
