Old 09-24-2022, 09:22 PM   #1
Franchise_24
Franchise_24's Avatar
Question Is it my carb?
When on a trip today with our club. Car ran great, but towards the end of the day when I would be in first or second gear and try to accelerate it would act like I lost power and sputter and backfire some. Once I got into third I was ok. I opened up the GAV some and it seemed to resolve it, but it happened again a few more times on the way home. Is this carb related? Does it just need cleaned up or do you have other suggestions?
Thanks,
Neal
1929 Model A Ford Coupe
Franchise_24 is offline   Reply With Quote
Old 09-24-2022, 10:00 PM   #2
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Re: Is it my carb?
If it was backfiring out the muffler, then it’s probably electrical. Erratic power to points will let gas through the engine and into the exhaust. When it refires, it explodes in the exhaust.,
Old 09-25-2022, 12:04 AM   #3
Tom Endy
Tom Endy's Avatar
Check the gap on the ignition points, they may have closed up on you. As the rubbing block wears, the points close up. It throws the timing off. Re gap to .020, you don't need to re-set the timing.
Tom Endy
Old 09-25-2022, 08:07 AM   #4
Franchise_24
Ok I will give it a try and check the points, thank you, and yes it was backfiring out the muffler.
Old 09-25-2022, 08:18 AM   #5
Bob Bidonde
Bob Bidonde's Avatar
Check the easy stuff first. A failing condenser can cause your experience, and so too can a frayed / broken wire under the distributor plate.
Bob Bidonde
