Old 09-06-2022, 10:07 AM   #1
katy
katy's Avatar
Default Greasing a Model A horn?
Should the "wobble wheel" on the end of the armature shaft have grease on it, where it conacts the dimple of the diaphram?
Old 09-06-2022, 10:18 AM   #2
31Tudor
31Tudor's Avatar
Default Re: Greasing a Model A horn?
Yes, a little bit
31Tudor is offline   Reply With Quote
Old 09-06-2022, 10:28 AM   #3
Will N
Will N's Avatar
I say no. Anything that can gum up the ability of the motor to spool up to full RPM quickly is right out.
Will N is offline   Reply With Quote
Old 09-06-2022, 10:32 AM   #4
31Tudor
31Tudor's Avatar
Been doing it for 30+ years when I have worked on a horn. Never an issue and it seems to hlelp the RPM to your point above for the tone of the horn. Just my experience however.
Old 09-06-2022, 11:42 AM   #5
alexiskai
alexiskai's Avatar
The horn is what you'd call a "light-duty" component. If you drove your car every day and sounded the horn twice a day on average, at the end of the year, the horn motor would have 12 minutes of use on it. I think it was for this reason that they didn't bother to grease the ratchet at the factory, despite it qualifying as a metal-on-metal sliding contact.
That said, there are good reasons to grease the ratchet:
  • Reduces energy lost to friction, so the horn can be louder without the ratchet being slowed/stopped by the diaphragm
  • Reduces wear on the contact surfaces, which is good in this era of parts shortages
  • Helps protect surfaces against rust
The horn rebuilders I know grease the ratchet. If you didn't grease it, you'd probably be fine too.
Old 09-07-2022, 09:18 AM   #6
JoeCB
JoeCB's Avatar
Remember "Brill Cream" .... a little dab will do ya'
applies here too
Joe B
JoeCB is offline   Reply With Quote
Old 09-07-2022, 09:28 AM   #7
alexiskai
alexiskai's Avatar
applies here too
Joe B
Any more than a dab will wind up splattered on the rim of the motor base the first time the motor spins up.
Old 09-07-2022, 10:07 AM   #8
katy
katy's Avatar
Thanks for the input.
Old 09-08-2022, 04:42 PM   #9
rotorwrench
rotorwrench's Avatar
I'd spray the horn motor ratchet with a coat of dry lube like Moly Koat and leave it at that. Too much lube and the diaphragm won't vibrate as well. That vibration is what makes the noise. The louder the better.
Old 09-09-2022, 09:51 AM   #10
katy
katy's Avatar
I have a big can of graphite grease, I'll try a smidge of that.
Thanks all.
Old 09-09-2022, 11:31 AM   #11
Y-Blockhead
Y-Blockhead's Avatar
It only mentions lubricating the armature in the Service Bulletins.
Old 09-09-2022, 12:52 PM   #12
alexiskai
alexiskai's Avatar
This is definitely a practice that has evolved out of the "folk tradition" of Model A maintenance rather than coming from the manufacturer. Doesn't mean it's bad, though. The Ford Service Dept wasn't trying to preserve these for 95 years.
Old 09-09-2022, 01:50 PM   #13
Y-Blockhead
Whatever, just passing along info...
Old 09-11-2022, 10:15 AM   #14
katy
katy's Avatar
I put a smidge of graphite grease on the "wobble wheel", works great.
Does anyone know the proper thickness of the gaskets for the diaphragm? Or does it matter? I made a couple because they were missing.
