Old 08-13-2022, 05:57 AM   #301
glennpm
glennpm's Avatar
Default Re: Engine temp rises when I get to cruise speed
Thanks Joe, I hope your test ride today works out for you.
Glenn
glennpm is online now   Reply With Quote
Old 08-13-2022, 11:41 AM   #302
glennpm
glennpm's Avatar
Joe, did you do anything else after you switched the Aluminum radiator?
I'm wondering if you have brakes dragging. smell and touch test on the brake drums will tell you this. The fastest you go the more this and air resistance will drag on the engine.
Old 08-13-2022, 03:40 PM   #303
jrvariel48
jrvariel48's Avatar
No changes were made after I installed the radiator. I have the MT 11" Lincoln style brakes up front and drums on the 9" rear. All adjusted well.
jrvariel48 is offline   Reply With Quote
Old 08-13-2022, 03:41 PM   #304
glennpm
glennpm's Avatar
Oh well ....
Old 08-13-2022, 03:54 PM   #305
jrvariel48
jrvariel48's Avatar
I took the car out this morning
63 degrees 61% humidity
I'm using a digital stop watch for the times listed below.
I started the car and let it idle. NO FAN.
4 minutes the temp was 150 degrees.
At 5 minutes, 30 seconds the drivers side t-stat opened
At 6 minutes the temp rose to 170 degrees
At 6 min/30seconds the passenger t-stat opened.
The seconds are approximate, but very close
8 minutes in I start to drive to the high way which is a couple of minutes away temp is 175
8 min/30seconds I hit 180 and turn on the fan. I got nervous!
9 minutes I reach the high way and turn off the fan. Fan was on for approximately 1 minute.
I drove on the high way for about 13 minutes at 60-65 mph at 180 degrees.
Got off the high way and hit the back roads for about 12 minutes at 30-45 mph and temp hits 185
Back on the high way for 14 minutes still at 185 and NO FAN.
Get off the high way for a short stop and go ride to my house and I hit 190 degrees as I pull in the driveway
Total run about 50 minutes.
It really like 63 degrees!
Old 08-14-2022, 12:27 PM   #306
cadillac512
cadillac512's Avatar
Well heck, Joe...I like 63 degrees too after this 102-104 every day here.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 08-14-2022, 01:04 PM   #307
jrvariel48
jrvariel48's Avatar
Terry
Damn Terry that’s too hot!
Old 08-16-2022, 05:55 PM   #308
B-O-B
B-O-B's Avatar
You boys need to venture out west. !07 as I type this & that isn't too bad.
B-O-B is offline   Reply With Quote
Old 08-17-2022, 02:11 AM   #309
jrvariel48
jrvariel48's Avatar
Yeah, no good!! 70 degrees is too hot for me!
Old 08-18-2022, 01:45 PM   #310
jrvariel48
jrvariel48's Avatar
I installed the Bob Shewman T-stats today. I might have a chance at a drive tomorrow.
I'll keep you posted.
Old 08-18-2022, 04:39 PM   #311
cadillac512
If nothing else, you're getting to drive around a lot!
Old 08-18-2022, 05:16 PM   #312
jrvariel48
jrvariel48's Avatar
HAHAHA!! As frustrating as this is, I really can't complain about seat time!
I'm really chasing about 10 degrees. After the T-stats, I was thinking of changing the pumps. I found out that they're Speedway pumps not Skips as I originally thought. I personally don't think the Speedway pumps are a problem, but process of elimination is key. I sent cores to Skip last week so I'm just waiting for them to come in. The saga continues!
Old 08-19-2022, 09:13 PM   #313
Tinker
Tinker's Avatar
I'm guessing you have boiled a pot on the stove with a thermometer to check when your thermostats opened.
Some guys are using volvo stat's as they fit and open at 170.
190 wouldn't bother me. Glad you are driving it and flushing the gremlins.
Old 08-19-2022, 09:56 PM   #314
40cpe
40cpe's Avatar
In 63 degree weather? What would it run in 95 degree weather?
Old 08-19-2022, 10:06 PM   #315
Tinker
Tinker's Avatar
Warmer. glad it's 63 in NJ.
Might be understanding Brassworks response a bit better now.
File Type: jpg Screen Shot 2022-08-19 at 10.08.23 PM.jpg (15.3 KB, 29 views)
Old 08-20-2022, 05:58 AM   #316
jrvariel48
jrvariel48's Avatar
Tinker I put then on the stove and saw they opened at about 180 degrees. (these are 160 degree t-stats) I don't know how accurate this test was. I really just wanted to make sure that they did open.
Old 08-20-2022, 06:12 AM   #317
jrvariel48
jrvariel48's Avatar
I took a quick test ride yesterday with the Bob Shewman stats. They look just like my old stats except there's 4 holes drilled through around the perimeter.
It was 90 degrees.
Here's the timeline:
5 minutes idle, no fan to reach 150 degrees
6 " " 160
7 " " 170
Start to drive at 7 minutes. Driving was stop and go up to 30 mph.
8 minutes in it went to 180 degrees
10 minutes in it went to 190
I put the fan on at that point.
15 minutes in I was at 200 degrees
Pulled car back in the garage.
I should be able to get some better info today with some high way time also.
Old 08-20-2022, 06:14 AM   #318
jrvariel48
jrvariel48's Avatar
Tinker it looks like we'll be getting more heat here in Jersey this coming week with temps reaching 90 degrees
Old 08-20-2022, 01:22 PM   #319
jrvariel48
jrvariel48's Avatar
I don't want to bore everyone with the details, but it was the same.
Start the car, drive the car park the car.
It was 75 degrees outside, temp was fine until i got on the high way and it went to 200 and then drops to 185 on the back roads
Old 08-20-2022, 03:38 PM   #320
cmbrucew
cmbrucew's Avatar
Joe
With all the work and time you have invested trying to make the brassworks radiator results better, why not put the ugly aluminum radiator back in and drive it.
Mount it on the wall and put a dartboard on it.
My .02 cents
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
