Old 08-08-2022, 12:46 PM   #1
Dude81
Default 57 with 312 rough when accelerating
57 Fairlane Sunliner with 312, Ford 4-barrel, and auto trans runs very rough when accelerating, especially at low speed. Causes car to shake. Does not occur unless car is in gear. Installed new U-joints and rear trans mount (engine mounts appear OK). No improvement. Engine has always "ticked" on passenger side--worse when idle and cold. Non ethanol 91 used. Suggestions?
Dude81 is offline   Reply With Quote
Old 08-08-2022, 01:38 PM   #2
dmsfrr
dmsfrr's Avatar
Default Re: 57 with 312 rough when accelerating
Could the transmission be slipping, not engaging properly?
Ticking noise on the passenger side...
Have the pushrods and valves been checked & adjusted recently?
See this link...
https://www.youtube.com/watch?v=SqG-Q_kVI3s
Old 08-08-2022, 04:05 PM   #3
KULTULZ
KULTULZ's Avatar
Post Re: 57 with 312 rough when accelerating
- IMO -
You need to diagnose the engine as to tune.
What carb does it have and how long since any engine work.
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 08-08-2022, 08:13 PM   #4
paul2748
paul2748's Avatar
How about engine mounts ?
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 01-22-2023, 06:51 PM   #5
Dude81
Thanks for the advice. Currently preparing to rebuild or replace the Carb (came from a 58 332/352).
Old 01-22-2023, 11:21 PM   #6
fordor41
fordor41's Avatar
See this link...
so I watched the video but he didn't start the engine. I scrolled down to another video he had where he adj. the valves on a for pick-up and started it up. OMG, if our Y-block sounded like that I'd s**t. other than a small tick on the pass. side when cold , our 292 Y-block sounds like a hyd. lifter engine. close the hood and can barely hear it run.
fordor41 is offline   Reply With Quote
Old 01-22-2023, 11:51 PM   #7
dmsfrr
dmsfrr's Avatar
Originally Posted by Dude81 View Post
. . . Engine has always "ticked" on passenger side--worse when idle and cold. ...
Exhaust manifold leak?
Old 01-22-2023, 11:54 PM   #8
40 Deluxe
Sounds like misfire under load. Coil could be weak. It only takes 5,000 volts or less to fire a plug at idle, whereas it will take 25,000 or more volts to fire a plug under load. The plug wires could be bad and leaking some of that higher voltage needed under load. Could be a bad condenser. Someone could have put too small main jets in the carb, or float level could be too low. Jets or passages in the carb could be plugged. Point gap could be off. Fuel pump could be weak. Fuel filter or fuel lines could be partially plugged.
Do a thorough tune-up. Do not assume anything. Make a check list and mark off every item until it runs smooth.
Old 01-23-2023, 12:22 AM   #9
Flathead Fever
Flathead Fever's Avatar
It's hard for me to know what shaking means. Is it shaking in the steering wheel? Where does the shaking feel like it's coming from? How bad is this shake? Is it an actual shake, a vibration or an engine running bad. A ticking lifter is not going to cause a shake in the chassis. A video would helpful. Did it always have this shake, did it start after something was changed?
Under acceleration the engine could torque to one side enough to allow metal to metal contact between the engine and something, and you could feel a vibration. Like if you had tight fitting headers that move far enough to touch part of the chassis. Can you have somebody you trust, put it in gear, set the parking brake and hold the brakes on while you stand to the "side" and give it a little gas and see if that engine is moving enough to make contact with something. Don't' you dare walk in front of it during the test.
Old 01-23-2023, 11:51 AM   #10
scicala
scicala's Avatar
It sounds more like a weak ignition problem to me.
Sal
scicala is offline   Reply With Quote
Old 01-23-2023, 01:25 PM   #11
dmsfrr
dmsfrr's Avatar
When did the car last have a basic tune-up?
Re-set the points & timing, clean or replace the sparkplugs, etc...
Old 01-23-2023, 01:29 PM   #12
oldbugger
oldbugger's Avatar
Always check the plugs first, look at the color, should be tan.
oldbugger is offline   Reply With Quote
Old 01-25-2023, 08:16 PM   #13
CSPIDY
CSPIDY's Avatar
I agree, ticking could be a bad plug
CSPIDY is offline   Reply With Quote
Old 01-25-2023, 08:20 PM   #14
paul2748
paul2748's Avatar
How about a bad vacuum hose or a disconnected vacuum hose? Check ll the hoses to make sure hey are in good condition. There are vacuum hoses under the dash.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 02-02-2023, 10:37 AM   #15
oldbugger
oldbugger's Avatar
Any updates, we would like to know what you found
Old 02-02-2023, 01:14 PM   #16
KULTULZ
KULTULZ's Avatar
Arrow Re: 57 with 312 rough when accelerating
You need to throw a vacuum gauge on it (IMO)
Old 02-04-2023, 09:55 AM   #17
Ford blue blood
Ford blue blood's Avatar
I'm going with week spark. At idle the fire makers don't much care how hot the spark is, under load a week spark will cause multiple mis-fires.
Bill, certified Ford nut.
2024 F-150
2018 Lincoln MKZ
2016 Focus
1961 Comet S-22
1956 Ford Crown Victoria
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 02-04-2023, 07:47 PM   #18
KULTULZ
KULTULZ's Avatar
Thumbs up Re: 57 with 312 rough when accelerating
- I Can Name That Tune In Ten Posts! -
Old 02-15-2023, 08:21 PM   #19
oldbugger
oldbugger's Avatar
HEY dude, whats up
Old 02-20-2023, 07:04 PM   #20
Dude81
Update: not so good. Sent the carb (a 1958 Ford 4100) off for a rebuild. Installed when it came back. Engine very hard to start and when finally did, it coughed, sputtered, backfired and then died. I tested the fuel pump by removing a line and watching the flow--looked good. Tested one spark plug and it fired ok once per revolution. Plug was slightly sooty, probably from over rich carb before the rebuild. Multimeter test on coil (Pertronix Flamethrower 3.0 ohm) showed 3.5 ohms between primary contacts, and 78000 ohms between contact and output (is that bad? I don't know what it should be). Coil is getting the full 12V needed. Distributor cap looks clean and solid. Points have been replaced by a Pertronix Igniter module. I'm researching how to test this. Any advice is appreciated. Also, if I decide to replace the coil and/or igniter, does anyone have suggestions? Thanks again.
