Old 07-31-2022, 06:10 PM   #1
rembrandt78737
Default Marvel shebler sticky float valve
I have a newly rebuilt marvel shebler carb for my 1929 model a Fordor. The float valve sticks. It’s the type that is gravity operated (no spring or anything connecting it to the float). It has a rubber tip that gets stuck continuously shutting off the fuel and stalling the car. I can rap the side of the carb to dislodge it but you can’t do that while you’re drive obviously. Anyone that has one of these figure out how to fix this issue? I’ve heard of using mineral spirits on the rubber to remove the tackiness of the rubber, but that didn’t work.
rembrandt78737 is offline   Reply With Quote
Old 07-31-2022, 09:47 PM   #2
Herb Concord Ca
Default Re: Marvel shebler sticky float valve
When I changed to the Viton tipped needle, the bag of parts included a spring that connects to the needle and the float. It forces the needle down so it won't stick.
Herb Concord Ca is offline   Reply With Quote
Old 08-01-2022, 06:14 AM   #3
rembrandt78737
The one provided didn’t accommodate a spring. Guess I’ll have to buy a new pin assembly.
Old 08-01-2022, 01:19 PM   #4
Herb Concord Ca
I buy mine from Steiner Tractor their part no is ABC 133.
