Old 07-19-2022, 09:10 AM   #1
poweredbylincoln
Default Correct spray paint for 33/34 steering wheel
Hi I want to know what spray paint to use for a 33/34 steering wheel?
Thank you
File Type: jpg 57127266-9855-4581-A16F-E843F22186A1.jpg (74.9 KB, 238 views)
poweredbylincoln is offline   Reply With Quote
Old 07-19-2022, 09:41 AM   #2
DavidG
DavidG's Avatar
Default Re: Correct spray paint for 33/34 steering wheel
Unless you need to paint the wheel to conceal repairs, they were originally unpainted.
Old 07-19-2022, 09:57 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
If you insist on painting your steering wheel, what I have used is single stage urethane with the necessary prep and a color of you choice.
It is wear resistant.
Old 07-20-2022, 12:33 AM   #4
highbeams
highbeams's Avatar
I had a wheel in very bad shape, so I filled the cracks w/ 'body mud'and dried for some time, then hand-sanded lightly, spray-painted black, spray-urethane.
Enjoyed driving, w/a great 'feel' - smooth as glass.
(If you must do the resto, and like high-gloss wheel, do it! (I had the wheel outta the cab when doing the thorough job. It looked outstanding.
highbeams is offline   Reply With Quote
Old 07-20-2022, 03:02 PM   #5
B-O-B
B-O-B's Avatar
I have used appliance epoxy rattle can black with good success
B-O-B is offline   Reply With Quote
Old 07-20-2022, 03:43 PM   #6
cas3
If the wheel is not in too bad a shape I have had good results wet sanding to about 1000 grit and hand polish with fine compound. Ends up smooth with a slight gloss
Old 07-21-2022, 02:46 AM   #7
poweredbylincoln
Thank you all I really appreciate it. I repaired a crack on the bottom and on the side and wanted to paint it to look nice and cover the primer on top of the repairs
Old 10-01-2022, 03:55 PM   #8
Lawson Cox
Lawson Cox's Avatar
I would not/did not use a primer. Wear will inevitably result and the primer will show through.
Just use a good paint with a hardener for "primer" and "top coat" and you won't have to worry about a primer showing through with wear.
I agree with Dave. Steering wheels were not painted.
Old 10-01-2022, 07:58 PM   #9
oldbugger
oldbugger's Avatar
when i did my 35 someone smarter than me said to use plastic bumper paint, it has a little flex built in. i used a satin black. Mine has lasted well
oldbugger is offline   Reply With Quote
Old 10-01-2022, 11:12 PM   #10
Dodge
I used rubber bumper paint about 20yrs. ago on my wheel and it still is in great shape.
Dodge is offline   Reply With Quote
Old 10-01-2022, 11:42 PM   #11
mercman from oz
mercman from oz's Avatar
1933-1934 Ford steering wheel - poweredbylincoln question?
Old 10-03-2022, 10:03 PM   #12
ken-r-mer
My recommend is an epoxy paint, rattle can, satin black. hard as nails. The satin hides hand prints better.
ken-r-mer is offline   Reply With Quote
