Old 05-16-2022, 07:59 AM   #1
Panheadguy
Smile 30-31 Roadster door question
What closes off the area between the door and the sub rail. With my door closed I can see the ground through the gap. No other cars locally to look at.
Thanks
Panheadguy is offline   Reply With Quote
Old 05-16-2022, 08:26 AM   #2
Planojc
Planojc's Avatar
Default Re: 30-31 Roadster door question
There is a rubber seal that slides in a channel on the bottom of the door. Got the seal from Brattons.
Planojc is offline   Reply With Quote
Old 05-16-2022, 11:48 AM   #3
midgetracer
midgetracer's Avatar
The repo doors I got from Brookville did not have the track to slide the seals onto. My original doors had the track.
midgetracer is offline   Reply With Quote
Old 05-16-2022, 03:59 PM   #4
gdmn852
gdmn852's Avatar
Hello, I believe Snyders has a lower seal that fits between the door panel and door edge for the Repo or original doors that don’t have the retainer. Your right on the gap , does seem large,
gdmn852 is offline   Reply With Quote
Old 05-16-2022, 04:00 PM   #5
Oldbluoval
Oldbluoval's Avatar
The pre mid 31 had a sweep at the bottom of the door panel. The 31 had a “keeper” track for a T rubber gasket that crimped in. I can be off on the swap over dates.
Old 05-16-2022, 04:20 PM   #6
gdmn852
gdmn852's Avatar
I checked on my car it had the channel ,rubber missing, it is a late 31.Odd they don’t make a repo channel, probably could be bent up on a brake press.
Old 05-16-2022, 05:27 PM   #7
Oldbluoval
Oldbluoval's Avatar
Gdmn
Yes easily made but not easily installed.
I have a Lenco panel spotter that I’ve used to put them on before
They’re just so narrow it’s hard to weld them on.
Maybe pop rivets???? Don’t likee them but sometimes…..
Old 05-17-2022, 06:13 AM   #8
Panheadguy
Thanks for the replies fellas. Yes its a Brookville body. Any pictures of the seal that is offered?
Old 05-18-2022, 01:22 PM   #9
Karl Wescott
Karl Wescott's Avatar
Part of the problem is that there are quite a few "they"'s. Some big and well known, some obscure, and some well known for other product lines. No one catalogs every part from every vendor.
Oh, btw, we make the channels.
Karl Wescott, Wescotts Auto
Karl Wescott is offline   Reply With Quote
Old 05-18-2022, 02:42 PM   #10
Oldbluoval
Oldbluoval's Avatar
If Karl makes it…..it top notch
BU
Old 05-18-2022, 03:23 PM   #11
gdmn852
gdmn852's Avatar
Learn something new every day, thanks for the post on the repro channel.In retrospect the “they “does sound some what conspiratorial (X Files)
