Old 04-25-2022, 08:50 PM   #1
Barnwood
Default What is the best way of removing a stuck brake pedal shaft collar on '31 Model A?
Barnwood is offline   Reply With Quote
Old 04-25-2022, 09:05 PM   #2
J Franklin
J Franklin's Avatar
Default Re: What is the best way of removing a stuck brake pedal shaft collar on '31 Model A?
A lot of penetrant oil and a bigger hammer!
J Franklin is online now   Reply With Quote
Old 04-25-2022, 09:25 PM   #3
mleder
Penetrant oil yes, if no go then, next step is heating with a torch and cooling to room temp a few times, when it is still hot push a candle into the joint and the wax can work as a lubricant, if no go gently cut each side almost through and break it with a chisel. It is a cheap part don't worry if you need to buy a new one,
mleder is offline   Reply With Quote
Old 04-26-2022, 10:02 AM   #4
katy
katy's Avatar
First, remove the pin that's holding the collar.
Old 04-26-2022, 11:14 AM   #5
J Franklin
J Franklin's Avatar
Talking Re: What is the best way of removing a stuck brake pedal shaft collar on '31 Model A?
Thanks for that one! It made me have a chuckle with my morning coffee.
Old 04-26-2022, 12:04 PM   #6
Patrick L.
Patrick L.'s Avatar
first, remove the pin that's holding the collar.
:d:d:d:d
