Old 04-18-2022, 05:34 AM   #1
rer_239
rer_239's Avatar
Default Exhaust paint
What do you use to paint an exhaust manifol?
Thanks
Dick
rer_239 is offline   Reply With Quote
Old 04-18-2022, 05:39 AM   #2
Wick
Wick's Avatar
Default Re: Exhaust paint
VHT cast grey. I heat the manifold up before spraying. For best results, buy a new manifold an use it.
They really make the engine look nice.
Wick is offline   Reply With Quote
Old 04-18-2022, 06:01 AM   #3
29spcoupe
29spcoupe's Avatar
2000 degree stove black. Looks great.
29spcoupe is offline   Reply With Quote
Old 04-18-2022, 06:21 AM   #4
nkaminar
nkaminar's Avatar
I just used the spray paint available from the local auto parts dealer. The manifold paint needs to go though a heat cure cycle. Use your gas fired barbecue. The instructions on the one I used called for heat-cool cycles of increasing temperature.
Don't forget the barbecue sauce.
Old 04-18-2022, 07:34 AM   #5
31Tudor
31Tudor's Avatar
I used a spray can product called Cast Blast.
31Tudor is offline   Reply With Quote
Old 04-18-2022, 09:46 AM   #6
Ray in La Mesa
X2 on Cast Blast, it lasts & lasts.
Ray in La Mesa is offline   Reply With Quote
Old 04-18-2022, 10:16 AM   #7
1crosscut
1crosscut's Avatar
x3 on the High Temp Cast Blast. Snyder's carries it or you can get it online.
Cure it on the gas grill, not in your house oven... trust me on that.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 04-18-2022, 10:52 AM   #8
chrs1961815
chrs1961815's Avatar
POR15 high temperature paint is the best and lasts for a long time unlike any aerosol paint imo.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 04-18-2022, 11:29 AM   #9
katy
katy's Avatar
Does them paints work on "been on the engine for years manifolds" or does the manifold need to be bare, rust free metal, like new or sandblasted?
Old 04-18-2022, 02:04 PM   #10
31Tudor
31Tudor's Avatar
I have only used the Cast Blast on manifolds that have been sandblasted and cleaned up.
