Old 03-19-2022, 09:10 AM   #1
AnthonyG
AnthonyG's Avatar
Default Water pump install question
What to use on pump to engine interface grease on gaskets or RTV?
Nomad
AnthonyG is offline   Reply With Quote
Old 03-19-2022, 09:30 AM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: Water pump install question
I use 'GasgaCinch' on many gaskets - it is a very thin sealer that comes in a can with an applicator in the top. I have used it for 40+ years on things like water pump surfaces, intake manifolds, etc..
RTV works fine as well (for waterpump gaskets), just don't buy the "blue kind" - looks like Hell no matter how much you wipe off!
Link: https://www.jegs.com/i/SCE-Gaskets/829/G1614/10002/-1
I use RTV on the oil pan and the ends of the rear/front main rope seals. Depending on the head gasket material, I usually use spray on 'CopperCoat' on them. One some applications I use Hylomar for the head gaskets (solid copper head gaskets).
Gasket sealers are one of the subjects where you'll get many opinions - and many different products and processes that ALL work . . . just pick your poison!
Old 03-20-2022, 10:38 AM   #3
19Fordy
19Fordy's Avatar
On my 8BA water pumps I use a thin coating of PERMATEX Non-Hardening gasket sealer.
Be sure to read this thread about NOT using RTV and silicone
https://www.fordbarn.com/forum/showthread.php?t=311227
Old 03-20-2022, 11:45 AM   #4
DavidG
DavidG's Avatar
Me too (Permatex).
Old 03-20-2022, 12:47 PM   #5
Lawson Cox
Lawson Cox's Avatar
Grease
Old 03-20-2022, 03:03 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
Anthony....Not to change the subject, but did you ever get your spindles/brakes project completed? I don't remember seeing any resolution on that. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-20-2022, 04:41 PM   #7
deuce_roadster
deuce_roadster's Avatar
The one time I used grease, it leaked. Always use Permatex or like product which never leaks.
Old 03-20-2022, 07:00 PM   #8
aussie merc
aussie merc's Avatar
another vote for non hardening gasket cement [permatex] defiantly not rtv of any kind
aussie merc is offline   Reply With Quote
Old 03-20-2022, 07:08 PM   #9
Lawson Cox
Lawson Cox's Avatar
Tighten it tighter. lol
Old 03-20-2022, 07:47 PM   #10
paul2748
paul2748's Avatar
Never had a problem with RTV - you have to use a very thin coating
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-21-2022, 03:39 AM   #11
Karl
Karl's Avatar
I use grease never had a leak (yet!)
Rolls Royce use Hylomar Blue on their engines I think -they don't leak much either
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 03-21-2022, 10:10 AM   #12
AnthonyG
AnthonyG's Avatar
DD, New info on juice brake project. While I did get the spindles reamed & KP’s fit well, I was planning on doing work in a metal pole building a friend is having built because my garage is pretty tight. But with builders being crazy busy it got postponed til April / May which puts us into May /June for a start. As I did quite a bit of engine refresh last season & don’t want to lose another season I think I’ll have some fun with it this season as is with the mechanicals which work as they’re supposed to & do the juice brake project in late fall later this year. I’ll definitely post progress when I start.
Nomad
Old 03-21-2022, 10:14 AM   #13
AnthonyG
AnthonyG's Avatar
Thx guys, I was leaning towards grease. It must have been assembled last build with grease, came off very easy & can barely see any residue barely had to clean & never leaked. Just putting hi-flow unit in.
Thx
Nomad
Old 03-22-2022, 05:26 PM   #14
uncle max
uncle max's Avatar
Hylomar was developed by the RAF to stop leaks on Rolls Royce-Merlin engined Spitfires. You could say it helped win the war.
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 03-22-2022, 09:02 PM   #15
Bored&Stroked
Part of the reason that Hylomar is such a good sealer is that it never truly sets up - it remains elastic, and fuel does not touch it . . . so it is good for many things. I have it in cans with applicators as well as spray-on. I use the spray on for blown applications with 0-ringed heads.decks and solid copper gaskets - works really well. But - it is not cheap!
Old 03-22-2022, 09:11 PM   #16
Pete
The words "good" and "cheap" seldom go together....
Old 03-23-2022, 12:09 AM   #17
bobH
thin layer of 'Right-Stuff'.... another one that is 'not cheap'
bobH is offline   Reply With Quote
Old 03-24-2022, 07:56 AM   #18
Bored&Stroked
Yep, but some folks keep thinking that cheap is "always good" . . . then they find out the hard way! LOL
Old 03-24-2022, 09:51 AM   #19
39fordtruck
What colour Hylomar?
39fordtruck is offline   Reply With Quote
Old 03-24-2022, 07:37 PM   #20
Bored&Stroked
The only color I've seen was blue . . . but I've not looking to see if there were others.
