Old 01-17-2022, 09:38 AM   #1
BashawT
Default Late 31 Tudor Windshield Filler Trim Question
Hey everyone,
I have an original filler trim that is rotted out. It has or "had" cage nuts that run along it. I purchased a replacement filler trim from Snyder's and it has no cage nuts or any holes at all. I am wondering what procedure those have followed when using a repro filler trim? Do these holes and cage nuts need to be added?
Thanks in advance!
- Travis
BashawT is offline   Reply With Quote
Old 01-17-2022, 09:59 AM   #2
Tinbasher
Tinbasher's Avatar
Default Re: Late 31 Tudor Windshield Filler Trim Question
If this is the part that goes along the top of the gas tank, yes you will need to drill the holes. you can bolt most of it but it will get tricky at the ends. The cage nuts make it easier to install.
Tinbasher is offline   Reply With Quote
Old 01-17-2022, 01:40 PM   #3
Brentwood Bob
The caged nuts, I believe, were on the 31. Majority of the filler strips I have seen have just the holes. I soldered on a fabricated tab at each end to attach to the pillar where the originals broke off. I slipped the tab into the top of the trim and soldered it in place. Locating the holes and installing caged nuts would take some effort.
Brentwood Bob is online now   Reply With Quote
Old 01-19-2022, 07:23 AM   #4
BashawT
Thank you!
