Old 01-07-2022, 07:41 PM   #1
old ugly
old ugly's Avatar
Default piston ring end gap spacing ?
i have always spaced the end gaps of the piston rings about 120d apart and not over the pin.
but
is there a chart or spec on the actual recommended spacing?
thank you
ou
old ugly
my mom would have told me. "these things are here to test us"
old ugly is offline   Reply With Quote
Old 01-07-2022, 11:38 PM   #2
Gary WA
Gary WA's Avatar
Default Re: piston ring end gap spacing ?
If you have Les Andrews Model A Mechanic book specs in there.
www.whidbeymodelaclub.com
Old 01-08-2022, 12:17 AM   #3
40 Deluxe
It makes absolutely no difference where the compression ring gaps are located! None! Rings randomly rotate in their grooves as the engine runs so they will at times be lined up. Guess what! Your engine starts and runs the same as always!
The only concern is that the oil ring rail gaps be offset on either side of the expander gap to facilitate installation.
We only stagger the compression ring gaps to honor an urban legend (old wives' tale, formerly).
Piston diameter in the ring land area is much smaller than the bore (to allow for expansion) so there is a lot of space for oil and/or compression blowby to travel from one ring gap to the other, while the ring gap itself is quite small. So the relative locations of the gaps is meaningless, no matter what old timers and "armchair experts" claim!
Old 01-08-2022, 12:13 PM   #4
katy
katy's Avatar
Originally Posted by old ugly View Post
I have always spaced the end gaps of the piston rings about 120d apart
Please explain "120d"
Old 01-08-2022, 12:45 PM   #5
old ugly
old ugly's Avatar
les andrews says 120d apart. its all i have been doing for years so i will just carry on as if i were normal.
thanks
ou
old ugly
Old 01-08-2022, 12:46 PM   #6
old ugly
old ugly's Avatar
i don't know how to make the little degrees sign.
old ugly
Old 01-08-2022, 04:04 PM   #7
katy
katy's Avatar
Hold down the alt key, type 2 4 8 on the right hand number pad, gives °
Do a search for alternate characters, lots of info available
Old 01-09-2022, 11:12 AM   #8
Jemelton#
Jemelton#'s Avatar
Thanks for the tip! Now I know what to do!
Jemelton# is offline   Reply With Quote
Old 01-09-2022, 11:30 AM   #9
Bob Bidonde
Bob Bidonde's Avatar
May be this will help:
Bob Bidonde
Old 01-09-2022, 12:12 PM   #10
Y-Blockhead
Y-Blockhead's Avatar
Or option, shift, 8 = ° on a Mac.
Old 01-09-2022, 01:26 PM   #11
Patrick L.
Patrick L.'s Avatar
120°
Old 01-10-2022, 09:45 AM   #12
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
I do agree with you 110% regarding the ring installation and gap alignment does not matter however most do not realize that if the rings are rotating randomly, this generally indicates a different issue which most of the time is a bent connecting rod. A bent rod will cause the piston to twist in the bore as it travels vertically in that bore. It is that twisting that can cause the ring to rotate. Otherwise the ring has the same contact 358° of the bore and nothing to push it into rotation.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-10-2022, 10:59 AM   #13
Patrick L.
Patrick L.'s Avatar
Rings can rotate in the bores, in theory. I find that they don't.
Old 01-10-2022, 11:17 AM   #14
40 Deluxe
If rings did not rotate in the bore, there would be a tiny unworn area at the top of the bore where the top ring gap was. Have you ever torn down a worn out engine with this unworn spot? In 60+ years of doing engine work I never have!
Old 01-10-2022, 11:19 AM   #15
40 Deluxe
Have you ever seen an engine with a tiny unworn spot at the top of the cylinder indicating the ring never rotated? I never have!
Old 01-10-2022, 02:27 PM   #16
old ugly
old ugly's Avatar
i was talking about the end gap spacing, the angle/position when installed onto the piston.
thank you
old ugly
Old 01-10-2022, 02:33 PM   #17
old ugly
old ugly's Avatar
haha
i tried all the suggested functions to make that little o. it don't work on my keyboard.
thanks tho
ou
old ugly
Old 01-10-2022, 03:18 PM   #18
Patrick L.
Patrick L.'s Avatar
I have, but, always because of a broken ring.
There shouldn't be a wear spot at the open end of a ring if the ring has been filed correctly. The other rings work/wear on the wall in that location.
Rings do move around, but, its not as if they rotate consistently.
Some pistons are pinned as to not allow rings to move at all.
Old 01-10-2022, 03:39 PM   #19
BRENT in 10-uh-C
To answer your question, ...yes, but again most rings today are gapless so it is moot.
FWIW, we monitor high-performance engines closely during assembly and then in teardown. The ring gaps are noted where they were installed and where they come out. They generally do not move, and usually it is because the piston was inserted and twisted as the rod was connected to the pin.
So going the other direction, what causes the ring to rotate?? Compression pressures are not going to rotate it, and if the piston is moving in a straight line within the bore, unless the rod is rotating the piston slightly during the cycle, tell me what is moving them??
BRENT in 10-uh-C
Old 01-10-2022, 06:34 PM   #20
40 Deluxe
But the other rings do not reach the top of the cylinder so can't "work/wear that location".
