Old 01-03-2022, 09:41 AM   #21
Gene1949
Gene1949's Avatar
Default Re: Looking for '49 wheat pennies
Originally Posted by 51 MERC-CT View Post
But if you were experiencing 'vapor lock' it may be a step toward reducing the problem.
The only times I experienced "vapor lock" was when one of the aforenoted conditions occurred. (Timing/ignition issues, engine heat, 6 volt battery or carb adjustment).
"Purists" seem to be plagued with vapor lock but the price you pay, I guess. Please believe me I'm not throwing rocks at "purists".
I made 1 trip to the Bonneville Salt flats many years ago and I decided then and there I would rather drive my car 70 mph in 115 degree heat then sit in a parking lot somewheres waiting for the engine to get cool enough to start.
That trip started my upgrades.
1st up was the conversion to 12 volts, an fuel pump with a factory Ford "bump switch" and a resin carb spacer. Pretty much solved the issue.
Gene1949 is offline   Reply With Quote
Old 01-04-2022, 03:50 AM   #22
aussie merc
aussie merc's Avatar
clean the passages in the manifold and use brass freeze plugs 3/4" from memory
aussie merc is offline   Reply With Quote
