Old 12-14-2021, 09:35 AM   #1
Robert/Texas
Robert/Texas's Avatar
Default Fuel Pump
The fuel pump in my ’37 Ford has a needle valve in it. None of the other fuel pumps that I have seen have this feature. What is the purpose of this?
Thanks, Robert,
Robert/Texas is offline   Reply With Quote
Old 12-14-2021, 04:47 PM   #2
DavidG
DavidG's Avatar
Default Re: Fuel Pump
It would be helpful to know "where" on the pump, but if it is external on the side of the upper body with a T handle and a spring on the threaded shank, it's the drain plug.
Old 12-15-2021, 08:46 AM   #3
Robert/Texas
Thanks David, that's where it is located. I don't see much use for it though. I believe that the pumps sold by the vendors didn't have this feature. I've used at least a half dozen of those over the years and none did. This pump was rebuilt by a reputable rebuilder and I just installed it. I’m confident that it will last for a long time.
Old 12-15-2021, 09:02 AM   #4
DavidG
DavidG's Avatar
It's original purpose was to permit you to drain off sediment trapped by the screen in the upper body of the pump. It was standard equipment on all '32-'34 pumps and was replaced with a special slotted screw with a fiber washer starting with the '34 V8 pumps.
Old 12-15-2021, 10:52 AM   #5
35fordtn
35fordtn's Avatar
As a side note if that drain valve is not seated and tightened properly the pump will not function. Personally I would not ever open it as it makes a mess of fuel on your intake
Old 12-20-2021, 09:23 PM   #6
Robert/Texas
Thanks to both of you. I don't plan to ever open this valve. I think that this fuel pump would go better with my '34 Ford though.
