Old 02-19-2016, 03:41 PM   #1
ebruns1
ebruns1's Avatar
Default 42-47 truck front fender brackets?
Fellas,
I searched the forums and I don't come up with anything on this...did the 42-47 trucks have any kind of front or rear brackets? My front clip does not have any and I'm trying to picture how it gets mounted to the cab and frame. Typically there is a front bracket that bolts to the radiator U-mount on other trucks I've seen. Some (Dodges) have a rear bracket on the cab too. Does anyone have a sheet metal diagram by chance?
Jim
ebruns1 is offline   Reply With Quote
Old 02-20-2016, 11:20 AM   #2
sunshine
sunshine's Avatar
Default Re: 42-47 truck front fender brackets?
MY 47 PKUP. HAS A BRACKET ON THE FRONT OF THE FRONT FENDER 8 INCHES LONG THAT BOLTS TO FRAME THRU A HOLE IN THE BUMPER BRACKET . THE REAR FENDER HAS A BRACE THAT GOES FROM THE REAR LIP TO THE FRAME ABOUT WHERE YOU WOOD HANG A MUD FLAP. I WISH I COULD SEND SOME PICTURES I HOPE THIS IS OF SOME HELP. I AM IN MD. IF YOU WOULD LIKE TO COME AND LOOK . [email protected] SUNSHINE
sunshine is offline   Reply With Quote
Old 02-21-2016, 09:35 PM   #3
ebruns1
ebruns1's Avatar
That is a great help Sunshine as at least I know I need to search out more missing parts. If anyone has a part number, sketch or nomenclature on the front bracket I would be extremely grateful!
Jim
Old 02-22-2016, 10:09 AM   #4
D. Jones
D. Jones's Avatar
The inner fenders bolt to the radiator core support and the frame. The fenders bolt to the inner fenders, the nose piece, splash pan and the running boards. There is a small flat metal bracket that goes from the frame to the bottom front of the fender to keep the flexing under control. Hope this picture helps.
D. Jones is offline   Reply With Quote
Old 02-22-2016, 11:07 AM   #5
willowbilly3
Originally Posted by ebruns1 View Post
Fellas,
Jim
I just dismantled a low mileage 47 2 months ago and I'm having a hard time visualizing the front fender brace you describe. The only brace on the front that I recall was this.
willowbilly3 is offline   Reply With Quote
Old 02-22-2016, 02:36 PM   #6
scooder
Willow Billy,
The bracket you show is the one up the top of the fender area, bolts to the radiator support and the front panel, yes?
Like you, my pickup (1942) had no other brace for the front fenders. One for the rear fenders, but none for the front.
Martin.
scooder is offline   Reply With Quote
Old 02-22-2016, 06:45 PM   #7
ebruns1
ebruns1's Avatar
Oh no...I definitely do not have a set of Willowbilly's brackets in the parts I got with the truck. Anyone happen to have an exploded schematic with parts numbers they could post to help us? Sounds like a few others are in the same boat.
Great photo D Jones! Your truck looks fantastic. I don't see that bracket in the photo, but it is still very helpful to see yours going back together!!! Man I'm jealous!
Old 02-22-2016, 08:23 PM   #8
willowbilly3
Originally Posted by scooder View Post
Willow Billy,
Martin.
Yes
Old 11-22-2021, 08:42 PM   #9
will.rynerson
will.rynerson's Avatar
Willow Billy,
Martin.
Hi all,
I’m to figure how these connect. Do they go on before the fender or can they go on after?
Thanks,
Will
will.rynerson is offline   Reply With Quote
Old 11-22-2021, 08:56 PM   #10
mercman from oz
mercman from oz's Avatar
42-47 Ford truck front fender brackets by D Jones
Old 11-22-2021, 09:06 PM   #11
will.rynerson
I’m trying to figure out where these (see the picture below) go. A picture is worth a thousand word. But…. :-)
File Type: jpeg FC7ECE17-6B49-478F-97C0-567420377E82.jpeg (118.6 KB, 71 views)
Thanks,
Will
Old 11-23-2021, 08:55 PM   #12
will.rynerson
Just in case someone else needs help figuring where exactly these go. Make sure you put these on before the fenders go on.
File Type: jpeg 1FF84239-A0B3-4B11-8CB5-8E378A28B594.jpeg (95.1 KB, 19 views)
File Type: jpeg 7827DF6A-D20E-4EA3-AF60-F2DFA4BA8957.jpeg (115.2 KB, 18 views)
Thanks,
Will
Old 11-24-2021, 05:15 AM   #13
mercman from oz
will.rynerson is trying to figure out where these parts go?
Old 11-24-2021, 05:22 AM   #14
mercman from oz
will.rynerson suggests:- " Make sure you put these on before the fenders go on."
Old 11-24-2021, 01:03 PM   #15
Doublepumper
Doublepumper's Avatar
Some pics...passenger side front and rear.
Ever stop to think and forget to start again?
Doublepumper is offline   Reply With Quote
Old 11-25-2021, 01:30 AM   #16
mercman from oz
Some pictures...passenger side front and rear - from Doublepumper
Old 11-25-2021, 11:38 AM   #17
GB SISSON
GB SISSON's Avatar
I have four jailbar trucks and I still get confused by the pile of small parts that are left over when I assemble the front sheet metal. I would love to save this thread as a great reference! That rear fender brace is rarely intact as it catches all the mud and salt . I have found that a galvanized strap on power pole cross-arms can be easily bent with a bit of heat to create a new and basically permanent fender brace. And they already have a 3/8" hole at each end!
Old 11-25-2021, 01:51 PM   #18
will.rynerson
Well,
I figured out where the heavy duty front brackets go. See pictures.
Thanks for all the help and searching.
File Type: jpg 3DB7544B-8D2D-471A-99B7-556BC05B2EAB.jpg (30.6 KB, 39 views)
File Type: jpg 2705340C-3BEF-4C2E-B2CA-FE44CEA64883.jpg (50.1 KB, 37 views)
Thanks,
Will
Old 11-25-2021, 03:05 PM   #19
GB SISSON
GB SISSON's Avatar
Will, were there coil springs with those brackets? From memory seems like A spring and long castelated bolt at one end?
Old 11-25-2021, 03:08 PM   #20
petehoovie
petehoovie's Avatar
Originally Posted by will.rynerson View Post
Well,
