Old 11-11-2021, 06:17 PM   #1
Shoebox
Shoebox's Avatar
Default 51 ford car-radiator placement
I went through this over 10 years ago and just can't remember. In a 6 cylinder car the radiator mounts ahead of the core support. In a V8 the rad mounts behind the support. Are there 2 different supports or (dare I say) like in a 55 chev, the radiator simply mounts in the front or back position? Thanks!
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 11-12-2021, 10:50 AM   #2
Shoebox
Shoebox's Avatar
Default Re: 51 ford car-radiator placement
Anyone?
32 Ford roadster
39 Mercury Towncar
Old 11-14-2021, 08:27 AM   #3
Ken Henry
Ken Henry's Avatar
I looked in my restorer’s guide but didnt see anything. Maybe the shop manual… You might try calling Chris at Shoebox central. Ken
Ken Henry is offline   Reply With Quote
Old 11-14-2021, 11:19 AM   #4
Shoebox
Shoebox's Avatar
Thanks Ken, .... what do you have for a "restorer's guide"?
32 Ford roadster
39 Mercury Towncar
Old 11-14-2021, 01:00 PM   #5
51504bat
51504bat's Avatar
Lee at Brassworks would know. I know they are super busy but when I ordered the radiator for my '39 p/u he spent a lot of time on the phone and by email to insure everything was correct. Nice guy on the phone and in person as well when I picked it up.
Old 11-14-2021, 04:17 PM   #6
fordy_nine
There are 2 different mounts but they also attach differently; the 6 cyl. part mounts in front and the 8 cyl. version mounts behind the crossmember....Bob L
fordy_nine is offline   Reply With Quote
Old 11-14-2021, 09:57 PM   #7
Shoebox
Shoebox's Avatar
Thanks for the response, I know the radiators mount in different positions, what I don't remember is if a different core support is needed, I am checking my service manual as I type this. Thank you.
32 Ford roadster
39 Mercury Towncar
Old 11-14-2021, 11:20 PM   #8
JHFORD51
The stamped u shaped core support is the same regardless of engine, 8A-16139. The sheet metal air deflector above the radiator is different, 8HA-8327 for the 6 cylinder.
JHFORD51 is offline   Reply With Quote
Old 11-15-2021, 07:33 AM   #9
Ken Henry
Ken Henry's Avatar
The book is 1949 50 51 Ford book, a restorer’s guide, published by the early Ford v8 club
Old 11-15-2021, 08:42 AM   #10
Shoebox
Shoebox's Avatar
JHFORD51,
THANK YOU, ........ that's what I had thought/hoped. I did just acquire an nos V8 air deflector. Ken Henry thanks, will have to add that book to the library.
32 Ford roadster
39 Mercury Towncar
Old 11-15-2021, 01:19 PM   #11
JHFORD51
The IPB also lists different front portions of the inner fenders (where the air inlets are for the interior heating and ventilation). I don't know for sure, but I guess for battery box installation. These are 8HA-16043 and 8HA-16055. Once had a 6 cyl car that had been retrofitted with a V8 and it fit fine; they never even changed the grille bullet so I know they didn't change the inner fenders!
This would be a good question with pictorial differences for the EFV8 49-51 advisor.
Old 01-31-2022, 04:43 PM   #12
amodel25
amodel25's Avatar
The 6 cylinder passenger side inner fender has a removable panel to allow access for servicing the valves.
amodel25 is offline   Reply With Quote
