Old 11-12-2021, 08:50 AM   #1
21stud
21stud's Avatar
Default 81A-7222 shifter housing detent balls and springs
I'm putting together toploader transmission and last part is shifter tower.
I have 2 different detent spring/ball kits, purchased from different suppliers some time ago. Both kit have smaller balls and other is also with smaller springs.
I remember one supplier said these are better than originals, they don't have original size.
Ford size is 7/16, next is 3/8 and 5/16
I just don't see any reason for these so called upgrades?
result will be sloppy at least?
maybe if you want sleeve that detent bore for these??
opinions please?
21stud is offline   Reply With Quote
Old 11-12-2021, 09:44 AM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: 81A-7222 shifter housing detent balls and springs
Sounds like a question for VanPelt. Did you change shafts and or forks? If so, does the machined place for the ball to land on the shaft different size then what came out?
I have a couple of those 81- shift tops I bought a very long time ago when I didn't know the difference between them and 91- tops because they both had detents on both sides.
Old 11-12-2021, 10:03 AM   #3
21stud
21stud's Avatar
I'm using same shafts and forks, good condition. So there is different shifter top, 91? and shafts? I didn't know that?
Old 11-12-2021, 11:03 AM   #4
Fred A
Fred A's Avatar
Do you believe everything you're told? John Cosper (Hot Rod John) sold a strong ball/spring set that he claimed was better. "Good Luck With That" Sponge Bob.
Fred A
Fred A is offline   Reply With Quote
Old 11-12-2021, 11:05 AM   #5
JM 35 Sedan
JM 35 Sedan's Avatar
opinions please?
Check with Michael Driskell @ Third Gen Automotive in McMinnville Tennessee. He will know what you need, and most likely has those items in stock.
John
Old 11-12-2021, 12:23 PM   #6
tubman
tubman's Avatar
Fred A
Is this the guy that posts all of the pictures of weird fabricated 4 carb manifolds that he has never used? The one who posts pictures of his cabriolet on every thread on the H.A.M.B. that has the least thing to do with flatheads?
Old 11-12-2021, 12:58 PM   #7
Bored&Stroked
Bored&Stroked's Avatar
I only run the original stuff . . . see no value in stronger springs.
If your transmission is popping out of 2nd gear, the problem is related to clearances and parts wear. There are plenty of rebuilds that pop out of 2nd (due to these sorts of issues) - and I know of no vendor that will guarantee that his/her transmission WON'T pop out of 2nd.
If you have any questions specific to clearances, parts or rebuild techniques, feel free to DM me.
Old 11-12-2021, 01:28 PM   #8
svm99
I agree, all the rebuilds I do use original 7/16" dia balls and original springs...................period. Proper clearances, shaft diameters, good pilot bushing/bearing in the flywheel and attention to detail when assembling minimize the chance of the transmission snapping out of second or hard shifting.
Use the original or NOS parts only! good luck Paul J.
svm99 is offline   Reply With Quote
Old 11-12-2021, 02:42 PM   #9
Als48
You can get bearing balls at any bearing house. You may need to ask for metric size. 7/16" would be about 5 mm.
Al Hook
Als48 is offline   Reply With Quote
Old 11-12-2021, 03:49 PM   #10
deuce_roadster
21stud, the earlier tops do not work with the better 91-a synchro as the fork is not wide enough. That is why many are looking for 39 (91-A) shifter tops and forks.
Old 11-13-2021, 01:16 AM   #11
Brian
Brian's Avatar
7/16" equates to 11 millimetres
Old 11-13-2021, 07:09 AM   #12
21stud
21stud's Avatar
Thank you all, good points.
Well, I didn't start this thread for asking what I should do with this shifter tower. It is allready assembled with correct size, good used balls and springs.
I just wanted to show what a man can get when just ordering new balls and springs to 81a shifter. just in case old ones turn out bad.
And I got 2 different sizes, all very wrong
I was wondering if someone actually has used these totally wrong size stuff in their tranny?
deuce_roadster,
I think there is confusion about part types. 81a top is double detent tower.
It could have earlier fork or later 91a 3" fork. I put it together with 3" fork and correct synchro.
afterall, these transmission are very simple to repair.
just watch out what spares you get...
Old 11-17-2021, 08:20 AM   #13
Talkwrench
Talkwrench's Avatar
Just assemble the tower and try them for feel . The smaller balls will have heavier springs and they "click" when going in and out of gear. I use them , well a combination I made up. They wont hold up if you have a second gear slipping problem tho'
Old 11-17-2021, 08:40 AM   #14
21stud
21stud's Avatar
Wouldn't smaller balls let forks move? 3/8 ball in 7/16 bore?
that's no good...
Old 11-17-2021, 11:02 AM   #15
rotorwrench
rotorwrench's Avatar
The main thing would be if the ball fits the coil spring ID, They don't move very much so I can see where a smaller ball might work but whether it works well in another question.
Old 09-11-2025, 05:20 AM   #16
34 FORDOR
34 FORDOR's Avatar
I just put up a post asking for detent ball size , did a search and found this post by 21 stud . You have answered my question . I have a detent spring and ball kit with small 3/8 balls which are loose in the housing bore and allow the shaft to move back and forth . The only way to stop this is use a much stronger spring , as many guys do. As 21 stud pointed out how many guys have used these kits with the wrong size balls . The only way to make them work correctly would be to sleeve the bore.
34 FORDOR is offline   Reply With Quote
Old 09-11-2025, 06:42 AM   #17
Tim Ayers
No, it's not the same guy. Hot Rod John died a fews years back. He was a fixture at Hershey.
Old 09-11-2025, 06:49 AM   #18
Tim Ayers
Thanks for posting Paul. Do you test your original springs or is this something that due to the light nature of it, they tend not to lose their tension?
Old 09-11-2025, 01:41 PM   #19
Brian
Brian's Avatar
You can convert the earlier trans top to double detent style. I modified my 35 sloping top about 50 years ago, can't remember the details....it involves grinding another notch in the selector fork shaft, opposite the existing 2nd gear notch, and using another ball and spring. In all my years of ownership, and the thousands and thousands of miles I've driven my 35, I can honestly say it has never, ever jumped outta second gear.
