Old 10-06-2021, 06:10 PM   #1
Tinbasher
Tinbasher's Avatar
Default Seam Sealer on 31 Tudor
Does anyone know where seam sealer was applied on a 31 Tudor? I know I'll be sealing the header to the visor and the header panel. Any other spots I don't want any water damage once the cars completed. JP
Tinbasher is offline   Reply With Quote
Old 10-08-2021, 06:04 AM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: Seam Sealer on 31 Tudor
If I knew I’d post!
Watching cause I’d like some authoritative feedback
I’ve only been working on open cars for the las 25 years but interested
Except for Vics
Old 10-08-2021, 08:06 AM   #3
Chris in WNC
Chris in WNC's Avatar
From my experience working on 3 different 30-31 Tudors, there was NO "seam sealer" applied at factory.
Welting around gas tank, fenders and running boards was it.
If your roof material is installed correctly, none will be needed.
no more model As for now........
Chris in WNC is offline   Reply With Quote
Old 10-08-2021, 10:55 AM   #4
Y-Blockhead
Y-Blockhead's Avatar
I see the vendors sell a 'visor welt' that goes between the sun visor and the wooden header.. I don't know if that helps you or not.
https://www.snydersantiqueauto.com/p...7757&cat=41654
Old 10-08-2021, 11:28 AM   #5
31Tudor
31Tudor's Avatar
That is correct that a seam sealer was not originally used. There was welting between the upper windshield panel and the underside of the visor; as mentioned cowl/ tank welting and that was about it on the body. Anything that you would put on, would be extra assurance but not done at the factory.
31Tudor is offline   Reply With Quote
Old 10-08-2021, 12:18 PM   #6
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
As mentioned above, no Seam Sealer other than Lead was used originally ....however a FWIW, we do use Seam Sealer in several areas on the top including using it above the Quarter Lock Pillar in the joint between the Roof (Side) Panel - ** and the upper portion of the A-56610/11 Quarter Panel Upper. If you will apply two pieces of masking tape about ¼" from each side of the joint, then apply the sealer and screed off, this will fill the joint and create a smooth transition for the top material to follow. Remove the tape when the sealer has tacked-up, then use Wax & Grease Remover and a Nitrile Glove to featheredge where the tape was.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-08-2021, 02:07 PM   #7
old ugly
old ugly's Avatar
my only advise is.
if you are going to seal stuff on the body. NO NOT use silicone sealer.
your painter will hate you.
ou
old ugly is offline   Reply With Quote
Old 10-09-2021, 02:36 PM   #8
Tinbasher
Tinbasher's Avatar
Thanks Guys. I'll be using a 2 parts seam sealer so I'll be good. Thanks for the Idea of sealing the roof joint over the "B" pillar Brent. I had forgotten about the 1/4 welt under the visor.
I'm OK, I know the painter!!
JP
