i'm rebuilding several 26-27 model T open car door latches.
does anyone know a source for replacement springs? or maybe what length they should be? mine are broken into 4 or 5 pieces so i know the diameter and wire gauge but can only guess at the length. thanks |
Langs has a door latch repair kit #5679-80RK includes all the springs and rivets needed to repair both the driver/passenger side door latches.
I would call and confirm with Steve over @ Langs, if they do not have what you need Chaffins or Snyders are other sure bets. Good luck and let us know how you make out with those springs. |
that kit appears to be for a coupe or closed car
Good News, Silent Rick located replacement Door Latch Springs. |
Rick,
I have some door latches that could use a refresh-- where did you find the springs? What is the wire size and diameter that matches the original (I haven't tried taking my latches apart). Thanks! |
