Old 08-30-2021, 03:14 PM   #21
Werner
Werner's Avatar
Default Re: Clear Distributor Cap
Russ,
please tell me who is /where I can found "Mikes".
Thanks in advance!
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 08-30-2021, 07:37 PM   #22
Bob C
https://www.mikes-afordable.com/
Old 08-30-2021, 07:50 PM   #23
Gene F
Gene F's Avatar
When I was a kid, I had a 1972 MonteCarlo. Those were all the rage. Then I talked with a guy at work about 40 yrs old. Gary was quite knowledgable about cars, and used parts. He told me "don't get one. they draw dampness for some reason, and your car eventually will not start". Sure it's cool, but only put it on for show. Reliability. I asked around, and heard the same story from other people.
Old 08-31-2021, 04:10 AM   #24
aermotor
I am not sure you are talking about the clear or cut away, at any rate I think both are cool and could be trouble shooting assistance. When it comes to dampness it doesn't matter as they can be changed back in 15 seconds. A new solid cap is less than $5.00 - I'm going to cut one away for the heck of it and have fun.
Thanks, John
aermotor is offline   Reply With Quote
Old 08-31-2021, 08:30 AM   #25
Tom Wesenberg
Tom Wesenberg's Avatar
I agree with John, and about 20 years ago I made my own clear cap by using a piece of thick Plexiglass. It makes a good diagnostic tool.
Old 08-31-2021, 08:41 AM   #26
Merc Cruzer
Merc Cruzer's Avatar
Originally Posted by noboD View Post
Picture gluing a clear thread together over and over. That is what 3D printing would look like. The solution type of 3D printer might work. But who's going to program it? To make a few it would be easy to make a mold and cast it.
All you need to do is scan an original.
Merc Cruzer is offline   Reply With Quote
Old 08-31-2021, 10:48 AM   #27
Keith True
Keith True's Avatar
I remember those clear distributer caps for modern cars,well they were modern in the late 60's when I saw them.They also sold red-clear plug wires.When the car was running the plug wires looked like modern LED light strings.I had a 59 Valiant in the early 90's that still had them on it.Fun to watch at night.
Old 08-31-2021, 11:03 AM   #28
Clem Clement
Clem Clement's Avatar
I have some for sale. $10 bucks plus postage.
Old 08-31-2021, 02:13 PM   #29
Werner
Werner's Avatar
Hi Clem,
i would like to have one piece please. If possible with "Ford"-script. Do you sell/ship to Germany? I would like to pay via PayPal please.
@ Bob, thank you for explanation.
Werner
Citroen 11 CV, 1947
Old 08-31-2021, 02:33 PM   #30
Werner
Werner's Avatar
Originally Posted by chrs1961815 View Post
The clear cap or cutaway cap are really just for curiosity, nothing diagnostic can really be done with them. I guess you could see if the distributor body had a short in it though.
Well, you can use it to diagnose when the capacitor starts to go bad.
Werner
Citroen 11 CV, 1947
Old 08-31-2021, 02:47 PM   #31
alexiskai
alexiskai's Avatar
Nu-Rex supplies a cutaway cap with their timing kit and recommends using a timing light strobe to observe the rotor action:
Focusing the timing light on the kit distributor cap permits observation of the rotor, cam, points, and electromechanical operation under running conditions. This kit can identify arcing at advance and retard positions. The rotor brass contact positions and arcing can be seen at retard, intermediate, and full advance positions. There should be no rotor contact with the distributor contacts; motion to each side at the extremes of retard and advance should be equal. Cam wobble and point motion can also be observed for uniformity of action. Internal arcing to ground or adjacent distributor contacts can also now be observed.
I have one but I haven't had time to set it up yet to see how useful it is.
Old 09-10-2021, 02:54 PM   #32
Werner
Werner's Avatar
Good evening at all.
Unfortunately, I couldn't find anyone who sells a transparent manifold cover. Creating a file for 3-D part printing is too expansiv. So I now tried to cast it by myself from epoxy resin.
I made the mold from two-component silicone rubber for third dentures from the original lid.
Unfortunately, the first attempt did not work. I had filled too less casting resin, too less vent holes on the upside mold and used an unsuitable wax for separation.
No. # 2 has been cast in the mean time and must now cure in the mold. I will report.
Werner
Citroen 11 CV, 1947
Old 09-10-2021, 03:00 PM   #33
alexiskai
alexiskai's Avatar
I admire this kind of commitment.
Old 09-11-2021, 03:29 PM   #34
Werner
Werner's Avatar
Danke für Dein Lob! -
The second attempt is successful, not very good but good; there are still some tiny air bubbles visible.
The next step is to insert an electric current carbon inside with some stepped brass sleeves.
I will report back.
Werner
Citroen 11 CV, 1947
Old 09-14-2021, 04:45 AM   #35
Werner
Werner's Avatar
Good morning!
In the meantime, my clear distributor cap is largely finished.
Patiently, the current lead through had to be tricky. From 4 short brass tubes I soldered the gradation for the sliding carbon contact and the ignition cable.
Sensitive was the filing of the central contact carbon alienated from a 'Walton' horn in a small square and round pin.
This is more watchmaker work than for a long stroke cast iron engine mechanic!
Werner
Citroen 11 CV, 1947
Old 09-14-2021, 03:20 PM   #36
Ivan in southeast va.
Ivan in southeast va.'s Avatar
I admire your persistent determination! Now, can you make a hundred of them and sell them for 5 dollars? Just kidding, great work!
Ivan in southeast va. is offline   Reply With Quote
Old 09-15-2021, 01:37 AM   #37
TomInCologne
TomInCologne's Avatar
Originally Posted by Werner View Post
<snip>
<snip>
May i ask you why you said this? Creating the 3D-files is free of charge?
TomInCologne is offline   Reply With Quote
Old 09-20-2021, 03:50 PM   #38
Werner
Werner's Avatar
Hi',
in the meantime, I have tested the transparent cover several times. Great disappointment was that the spark jumps are very mild and barely visible.
Joy was to recognize by it, that the condenser and the plugs resistors are in order.
On a trial basis, I increased the electrode gap considerably on one spark plug and this could be seen well on the distributor contact.
In short: The glass cover is not a toy, because with a little experience quite suitable for engine diagnosis.
Cologne; don't understand your shortquestion.
Werner
Citroen 11 CV, 1947
Old 09-21-2021, 11:21 AM   #39
katy
katy's Avatar
I'm wondering, why the tie wire on the distributor body terminals?
Old 09-21-2021, 11:43 AM   #40
aermotor
Hi',
I have a cut away side cover and was also disappointed in spark size - much more obvious at night.
John
