Old 08-06-2021, 07:14 AM   #1
Veeder
Default Transmission End Play (stock 41)
I've rebuilt the tran. And in the final stages of assy. I do have a little bit of end play when pulling on the spline rear shaft (1/8 inch approx.) Based on what I've read on Vapelts Web site (super helpful) that is not acceptable. I'll call them Monday as I believe they have washers for this issue.
Would like to hear from someone who may have dealt with this successfully.
Bob
Veeder is offline   Reply With Quote
Old 08-06-2021, 07:59 AM   #2
Zeke3
Zeke3's Avatar
Default Re: Transmission End Play (stock 41)
Do you have the universal joint installed on the end of the shaft? It took all the end play out of my 1937 trans when the joint is bolted in place.
Zeke3 is offline   Reply With Quote
Old 08-06-2021, 09:54 AM   #3
Veeder
I do not and wow I was wondering if the Universal joint had anything to do with it. I don't have a U Joint to try it but very very good information thank u
Bob
Old 08-06-2021, 10:50 AM   #4
HD Rider
Bob
There's the problem. When you tighten the ujoint, it pulls the output shaft tight against the rear bearing.
HD Rider is offline   Reply With Quote
Old 08-06-2021, 02:34 PM   #5
Veeder
Many thks guys! And yes you will love it building a frame to protect this thing for 6 mths or so I dropped it as the frame was not quite done but the 2x4 protected the tran case but the rear mount broke. Lovely!!! U gotta love it
Old 08-06-2021, 04:11 PM   #6
Bored&Stroked
Bored&Stroked's Avatar
Hey guys, I don't believe the u-joint has anything to do with it . . . will check a 39 box that I just finished in the AM.
With that said you have to have the transmission mount on the box to hold the rear bearing in (or it can move backwards) - so if you don't have the mount on, then use a 3/8" bolt with a big washer and thread it in the back so the washer holds the bearing in place.
Old 08-06-2021, 05:48 PM   #7
Veeder
Thks Bored and stroked it would be nice to confirm the situation otherwise I must be looking at putting shims in
Stay tuned
Old 08-06-2021, 08:41 PM   #8
Bored&Stroked
Veeder - when you mention play - what is it? Is it the main-shaft moving inside the bearing at the rear? I've never seen that - so please explain?
Old 08-06-2021, 09:17 PM   #9
bbrocksr
U joint clamps/secures the shaft to the bearing, rear bearing retainer/rear mount clamps/secures the bearing to the case. Both must be secured before checking endplay,
Bill
bbrocksr is offline   Reply With Quote
Old 08-06-2021, 09:28 PM   #10
HD Rider
Bill
Nailed it.
Old 08-06-2021, 09:33 PM   #11
Bored&Stroked
Bill
So explain how it works when you have an open drive transmission shaft with a slip yoke on the back? Same transmission, just different main shaft. I will checkout both main shafts tomorrow . . . as I'm curious myself.
Old 08-06-2021, 11:10 PM   #12
svm99
The open drive rear bearing is retained on the shaft by the speedometer drive gear and a snap ring. I've found the speedometer gears to be in slightly different widths to minimize the end play when the snap ring is put in place.
svm99 is offline   Reply With Quote
Old 08-07-2021, 05:20 AM   #13
Veeder
Great information thks again!
Now it's time to find a new rear bearing retainer. Seems like there are multiple types. I still can't believe I dropped it unbelievable. Have a great day guys my 41 is going for a ride today!!!!!
Old 08-07-2021, 06:29 AM   #14
Terry,OH
Terry,OH's Avatar
The front and rear bearing outer retaining snap rings must be of the proper thickness as the originals. 0.075-0.080"
Old 08-07-2021, 07:11 AM   #15
Ol' Ron
Ol' Ron's Avatar
Back in the day, we we would meadure the distance between the inside of the two retiner rings on the fron and rear bearings in a lathe. with the assemble held tight, all .006/.008" and machine the case to match. Tis kept the trans from jumping out of 2nd. it also kept them together behind the Oldsmobile engines. Later I was told this was wrong and you should use shims, but I don't know where you'd put the shims. It was about this time the cad/LaSal trand got popular. Maybe somebody will remember this.
Gramps
Old 08-12-2021, 09:57 AM   #16
Veeder
Mounting the U-joint took all the end play out just an update
Old 08-12-2021, 10:03 AM   #17
FRANK PKNY
FRANK PKNY's Avatar
The shims would be correct prior to loading th u joint. Do you have VanPelts book? it goes over this aspect.
FRANK PKNY is offline   Reply With Quote
Old 08-12-2021, 11:03 AM   #18
Karl Wolf
Karl Wolf's Avatar
Mac VanPelt has an excellent transmission book.
Get one
Karl
Karl Wolf is offline   Reply With Quote
