Old 07-16-2021, 03:00 PM   #1
doug.nichols
doug.nichols's Avatar
Smile Battery Terminal Multiplier
I am looking for some kind of gadget that would allow me to attach multiple wires to the negative pole of my 12v battery without just stacking them on the bolt that holds the ground wire to the terminal. Does anybody know of such a thing?
doug.nichols is offline   Reply With Quote
Old 07-16-2021, 03:32 PM   #2
alexiskai
alexiskai's Avatar
Default Re: Battery Terminal Multiplier
These are pretty common, here are two examples.
Old 07-16-2021, 07:48 PM   #3
shew01
shew01's Avatar
Default Battery Terminal Multiplier
Or maybe something like this?
WUPP 12 Volt Fuse Block, Waterproof Boat Fuse Panel with LED Warning Indicator Damp-Proof Cover - 6 Circuits with Negative Bus Fuse Box for Car Marine RV Truck DC 12-24V, Fuses Included https://smile.amazon.com/dp/B07GBV2M...EAK63722X89T2T
I glued magnets from Lowe’s on the back of my fuse
block and it works great without drilling a mounting hole.
Old 07-16-2021, 10:30 PM   #4
bruceincam
bruceincam's Avatar
Or as another example:
https://www.snydersantiqueauto.com/P...-a/accessories
I have this one and it's an easy install and works well ---- I've forgotten the count, but it's like 6 grounds and 6 positives.
bruceincam is offline   Reply With Quote
Old 07-18-2021, 08:08 AM   #5
PalAl
PalAl's Avatar
Then there is the era look......
Hmmmm "era look" with an alternator, ha, ha
I beat you guys to the punch
PalAl is offline   Reply With Quote
