Old 05-30-2021, 08:39 PM   #1
IndianapolisRacer
Default Offenhauser manifold carb linkage
I have a 2 carb Offenhauser intake manifold with twin 97s on it but having difficulty finding the correct throttle and choke linkage for this unit .Where do I find the rods and connectors ?
IndianapolisRacer is offline   Reply With Quote
Old 05-30-2021, 10:23 PM   #2
Charlie ny
Default Re: Offenhauser manifold carb linkage
I like 3/16 dia steel round stock, HEIM ends & throttle arms from Speedway. Check
page 280 in the Speedway catalog.......items 5601007 thru 6181 and HEIM ends
175-0100 & 175-0200 page 10
Charlie ny
Old 05-31-2021, 07:56 AM   #3
deuce lover
deuce lover's Avatar
www.stromberg-97.com/linkage. Then click "speed parts".Many many examples of what they handle.
I presume its for your '32,right?
For the choke,depending on the spread of your carbs you might not be able to use the '32 choke rod as it was.You might have to shorten or lengthen it. If you prefer to run a cable choke,I have this that can work but you have to change out the kicker linkage.
