Old 05-25-2021, 02:10 PM   #1
poolplayer1
Default Just a simple question that is not ford related.
I know this is not the place to ask a question on anything other than ford. Maybe you guys can help and maybe not but I will ask anyway. Do any of you know of a good chevy forum that I can go to for help? I bought this 1994 chevy brand new in that year.It has a 350 tbi with 160,000 miles. I need to talk to a chevy group that may be able to help me fix my truck.The dipstick shows a very milky looking oil.Thanks.
poolplayer1 is offline   Reply With Quote
Old 05-25-2021, 02:34 PM   #2
dmsfrr
dmsfrr's Avatar
Default Re: Just a simple question that is not ford related.
Coolant in the oil is the usual cause of milky looking oil.
You may also find a bit of oil or unexplained bubbles in the radiator???
Finding and repairing a blown gasket could be one of the easier repairs. Worse causes are possible.
dmsfrr is online now   Reply With Quote
Old 05-25-2021, 02:44 PM   #3
poolplayer1
Thanks dmsfrr for your response.I did a combustion leak detection test with the fluid and ran the engine for 15 minutes.The fluid stayed blue all the time,never changed to yellow.The temp gauge barely reached half way,never got hot. I am suspecting a bad intake manifold gasket.
Old 05-25-2021, 03:37 PM   #4
5851a
https://chevroletforum.com/forum/sil...e-pick-ups-21/ Might try here.
5851a is offline   Reply With Quote
Old 05-25-2021, 04:05 PM   #5
Los_Control
I feel your pain. I have a 1991 chebby truck. There is a Silverado forum. I have joined and asked some basic questions, I get very few replies ... A 1990's truck is a antique to them. They are all talking about led lighting, lift kits, tires, paint striping.
While I will also look at @5851a link & check them out.
I would also suggest the https://www.garagejournal.com/
They are very active, the forums cover many subjects. You can talk about your house repairs, garage, tools, cars, motorcycles, gardens, guns .... pretty much anything but politics.
You would get some great help there with your problem.
You got flathead Ford problems, here is the right place.
Los_Control is offline   Reply With Quote
Old 05-25-2021, 04:33 PM   #6
KULTULZ
KULTULZ's Avatar
Post Re: Just a simple question that is not ford related.
If just the mix is on the upper end of the dipstick (and the dipped oil is not milky) and possibly under the oil filler cap, it sounds more like a non-functioning PCV SYSTEM.
Also, if the engine does not come to proper operating temperature, (coolant), it magnifies the problem.
The test you performed was only to find any combustion gases in the coolant. You would need to perform a cooling system pressure test to see if the system holds pressure.
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 05-25-2021, 08:19 PM   #7
Fortunateson
I guess the only real permanent fix for your Chevy is to replace the engine with a Ford! LOL
Fortunateson is offline   Reply With Quote
Old 05-26-2021, 02:46 PM   #8
poolplayer1
Thanks guys for all your suggestions.I will check the links that are mentioned here.
I did think about putting in a 351 windsor engine in this baby but I decided to leave it origional.Ha Ha
Old 05-29-2021, 01:22 AM   #9
Alaska Jim
Alaska Jim's Avatar
If you suspect a blown head gasket, which can also result in having oil in the coolant, do a compression test.
Alaska Jim is offline   Reply With Quote
Old 05-30-2021, 03:54 PM   #10
Ole Don
Ole Don's Avatar
Loosen the radiator cap one notch, keep an eye on the temp gauge. Change oil ASAP.
Ole Don is offline   Reply With Quote
