Old 05-17-2021, 05:10 PM   #1
Anteek29
Anteek29's Avatar
Default Tillotson Seepage Fix
I prefer my Tilly X over a Zenith carb but had some seepage at the top/body gasket. I've read some Tilly carbs' pot metal has a tendency to warp so I disassembled the carb and checked the mating surfaces with a flat file. The body was perfectly flat but the top did have a slightly low portion which I decided to clean and fill in using JB Weld and then filed flat to match. (From what I've read, JB Weld is impervious to gasoline.) Re-assembled the carb with a new gasket and all seems tight and dry so far.
Also, I believe it is important that the 3 assembly screws are not overly tightened - to avoid either warping the pot metal or stripping the threads.
No, in this particular case I chose not to go with the heat/clamp option published elsewhere on this Forum.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 05-18-2021, 10:44 AM   #2
katy
katy's Avatar
Default Re: Tillotson Seepage Fix
Sounds good, here's hoping it lasts
Old 05-18-2021, 12:42 PM   #3
burner31
burner31's Avatar
I went with the heat and clamp option, seemed to work for me.
Been about three years and no leaks as of yet.
Keith
Shawnee OK
'31 SW 160-B
