Old 05-17-2021, 06:49 PM   #1
LAV
LAV's Avatar
Default Carb, Tillotson, Air Balanced
Anyone have a problem getting a new Carb, Tillotson, Air Balanced to run? I had to make a lot of adjustments to the float level to get to run when I first got it. I bent the float and used shims. After a few days of running well it stop and I have had problems since. My fuel is clean. Ive had to set the float level to 1.3” to stop leaking. I can get it to run periodically but when it does it rough. Nothing I do adjusting makes much difference. Could use some suggestions, Thanks.
LAV is offline   Reply With Quote
Old 05-17-2021, 06:57 PM   #2
nkaminar
nkaminar's Avatar
Default Re: Carb, Tillotson, Air Balanced
Did you fill up the gas tank? Perhaps additional pressure is causing a marginal float valve to leak. If you have to set the level that high then there is a problem with the float valve. Look at the exhaust to see if it is black with carbon or look at the plugs for the same reason. You may have to send the new Tillotson back for repair under the warranty. Try turning off the fuel to see if it runs better as the level in the carburetor goes down. You should not have to mess with the float level to make it run right. Send it back.
I bought a used Tillotson that had been rebuilt and have had no problems with it.
One other thought: If you are using an air filter, take it off to see if that makes a difference.
nkaminar is online now   Reply With Quote
Old 05-17-2021, 08:08 PM   #3
Anteek29
Anteek29's Avatar
Problem is with the float valve.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 05-17-2021, 09:45 PM   #4
Herb Concord Ca
Try using a Viton tipped float valve.
Herb Concord Ca is offline   Reply With Quote
