Old 04-05-2021, 08:01 PM   #41
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 1cm
Originally Posted by 36coupe View Post
My Mercury engine still has a lot of the original green paint ECM heads 4” crank and it came with a 3 bolt manifold and a strange tower on the 3 speed that the shifter came forward up over the back of the engine.
Are you maybe talking about a trans with a shifter like this? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-05-2021, 08:11 PM   #42
Holeshot
Default Re: 1cm
Originally Posted by GB SISSON View Post
Not a betting man, but I'm hoping the zip tie says it's a 255. That truck that it's in is already a hotrod. Put a license plate on it (or not) and run it into town on a Saturday night. What could possibly go wrong?
And Nitrous, don't forget the Nitrous.
"Sometimes he would accuse chestnuts of being lazy, the sort of general malaise that only the genius possess and the insane lament."
Holeshot is offline   Reply With Quote
Old 04-06-2021, 09:34 AM   #43
rotorwrench
rotorwrench's Avatar
Default Re: 1cm
Those Lincoln side shift set ups were definitely different.
Old 04-06-2021, 10:24 AM   #44
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 1cm
Ha! You wanna see "different"? You ALSO wanna see "side shift set-up"? Compare the bolt pattern on the SHIFTER cover on BOTH boxes....they are both the same Lincoln Zep CASE! Does everyone realize what the BOTTOM transmission was used in? DD
T5 W/TORQUE TUBE
Old 04-06-2021, 12:57 PM   #45
51504bat
51504bat's Avatar
Default Re: 1cm
Given the clutch arm on the right side of the trans I'd guess English or Aussie but of course that is just a guess.
Old 04-06-2021, 09:03 PM   #46
Fortunateson
Default Re: 1cm
Export if made in Canada or the US to commonwealth countries that drove on the original side of the road.
Fortunateson is offline   Reply With Quote
Old 04-06-2021, 11:20 PM   #47
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 1cm
Does everyone realize what THIS transmission was used in? DD
Simply put, it's a RHD (Right Hand Drive) trans used 1940-'48, as in the second picture below! It's interesting to note that the INSPECTION Cover and the 'Serial #' pad are not lined-up straight on these. DD
T5 W/TORQUE TUBE
Old 04-07-2021, 06:09 AM   #48
36coupe
36coupe's Avatar
Default Re: 1cm
This is a valve from the mercury block, I guess the C stands for Canadian.
File Type: jpg D2D85D41-002F-4F39-9204-ECC9793FC90C.jpg (35.2 KB, 15 views)
36coupe is offline   Reply With Quote
Old 04-07-2021, 07:44 AM   #49
rotorwrench
Default Re: 1cm
If Ford of Canada changed to rotator type valves than that is likely an example of the Canadian part. They used the C in the prefix on a lot of their parts.
Old 04-07-2021, 11:37 AM   #50
Ross F-1
Ross F-1's Avatar
Default Re: 1cm
Originally Posted by Beater View Post
hard to say what to do with it. it sits and does nothing
That's a '52 hood on the truck, the hood trim also appears to be '52. Can you post the serial number?
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 04-07-2021, 07:01 PM   #51
Beater
Beater's Avatar
Default Re: 1cm
could be its registered as a 51
Beater is offline   Reply With Quote
