Old 04-05-2021, 07:15 PM   #1
Talkwrench
Talkwrench's Avatar
Default Up and running again..but..
Well I fired the engine up yesterday with no real issues, disappointed that it didnt fire first crank like the least one I did but I did play with the carbs , no leaks all seems good except for the new clutch its horrible!! The flywheel was lightened, balanced , faced. It just seems to "take up" real quick and shudder bad if you dont slip it with revs .. Any tips would be appreciated ..
https://www.youtube.com/watch?v=kDhLKuxDAZ8
Old 04-06-2021, 01:33 AM   #2
Lawrie
Lawrie's Avatar
Default Re: Up and running again..but..
Where did you get the clutch from,New does not mean good.
shuddering could be oil or grease on the faces. did you clock up the flywheel face after you bolted it up to the crank?
check the pressure plate?
Lawrie
Old 04-06-2021, 07:20 PM   #3
Talkwrench
Talkwrench's Avatar
The Plate came from Dave Slatter , its the one that has the little shroud covers on the springs. He said hes never had issues and talked about springs popping out with other styles, Phil just installed one here and said it was fine. Spotlessly cleaned when I installed. No I didn't check for run out ,you assume that when you have them faced they know what they're doing..but ... and pressure plate was one I'd used before . The big issue is it just engages quick and hard, just bang! and its on .. I have to get the timing really good, dropping down to second and if the revs aren't right bang! it just grabs, reversing is just a shuddering mess..
