Old 04-01-2021, 05:54 AM   #1
39portlander
39portlander's Avatar
Default Not enough power up hills....
Picked up a nice 32 barn find that started and drove good except when going up slight inclines or hills.
I was only able to buy this as the previous owner claimed "it was half off" the asking price.
Opened the pictured bottom end and it appears to be missing 4 cylinders, any input would be great.
39portlander is offline   Reply With Quote
Old 04-01-2021, 06:39 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Not enough power up hills....
That's because it's a model 'B'
Old 04-01-2021, 06:58 AM   #3
Charlie ny
Hold on boy whatja got is an improved (1 2 3) 4 cylinder motor with fuel pump so at least you don't have to back up hills.
Charlie ny
Old 04-01-2021, 07:27 AM   #4
Kurt in NJ
Kurt in NJ's Avatar
looks more model T to me
Old 04-01-2021, 07:34 AM   #5
jimTN
Kurt, I believe you have it right! As for power, I would suggest checking the rear end ratio.
Old 04-01-2021, 09:28 AM   #6
Tim Ayers
I'm assuming this is an April Fool's post. 1/2 off asking price due to missing 4 cylinders. Should have had a V8
Old 04-01-2021, 09:32 AM   #7
chap52
chap52's Avatar
The turn signal lever doesn't work either??? Chap
Old 04-01-2021, 12:13 PM   #8
ford38v8
ford38v8's Avatar
That’s an easy call. If all cylinders don’t kick in when needed, your Northstar computer is obviously at fault.
Alan
Old 04-10-2021, 09:22 AM   #9
fortyonerag
fortyonerag's Avatar
Engage the starter for those extra power surge needs.
fortyonerag is offline   Reply With Quote
