Old 03-15-2021, 02:46 PM   #1
hardtimes
hardtimes's Avatar
Default Head Stud Q...
Do parts suppliers sell an OVERSIZE head stud for A/B use ?
Old 03-15-2021, 02:51 PM   #2
tinkirk
tinkirk's Avatar
Default Re: Head Stud Q...
ARP will probably have what you might be looking for
tinkirk is offline   Reply With Quote
Old 03-15-2021, 03:00 PM   #3
alexiskai
alexiskai's Avatar
Bratton's does. They also sell the oversized tappets – there was talk in another thread about those.
https://www.brattons.com/catalogsear...t/?q=oversized
Old 03-15-2021, 04:57 PM   #4
hardtimes
hardtimes's Avatar
Thanks much !
Ill contact ARP.
Old 03-15-2021, 10:26 PM   #5
dansluck
Send a message via AIM to dansluck Send a message via Yahoo to dansluck
Berts sells a head stud that has a bigger base and a standard upper . it can be used to repair a block without drilling the head.
dansluck is offline   Reply With Quote
Old 03-15-2021, 11:18 PM   #6
hardtimes
hardtimes's Avatar
Excellent, thats what I’m into right now. Just finished drilling out seven broken head studs.
FREE hand ! NO broken drills.
Finally figured out the formula.
Old 03-16-2021, 04:44 PM   #7
john in illinois
john in illinois's Avatar
You might helcoil and use standard studs.
Welcome each day
john in illinois is offline   Reply With Quote
Old 03-16-2021, 06:39 PM   #8
Synchro909
Synchro909's Avatar
That's what I have done many times (never more than once on any particular stud )
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 03-16-2021, 06:51 PM   #9
nkaminar
nkaminar's Avatar
If you drill and tap the block for larger studs or helicoil inserts, use an sacrificial head to guide the drill, even if you have to enlarge the holes in the sacrificial head. Otherwise you stand the chance to have the studs bind in the head you plan to use.
nkaminar is online now   Reply With Quote
Old 03-16-2021, 10:06 PM   #10
johnneilson
I am going to try and be gentle here, but, hand drilling out studs is just bad practice.
The reasons are many, such as drilling off center, going too deep and breaking into the water jacket and just ending up with crooked studs. There are people with the machinery to do a proper job, in most cases the studs can be removed and the threads saved in the block.
I see blocks that are butchered up so bad that I just refuse to make anything other than farm implement ballast out of them. I have done the time savers, made sealed inserts and done heli-coils. All of the fixes work, for a while. Over torquing will just accelerate the failure rate.
FWIW, a properly installed heli-coil will test to 75 ft/lbs or higher. No good blocks were used in this testing. Just doing proof of concept.
John
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 03-17-2021, 05:42 PM   #11
Gene F
Gene F's Avatar
Thanks John.
Old 03-17-2021, 07:36 PM   #12
zzlegend
zzlegend's Avatar
John
Good advise John. Not that it matters but last week i removed 5 broken studs on a B block i picked up. Used my mig welder and the washer and nut trick. Patience and carefully removed them. Now what to do with this block?
zzlegend is offline   Reply With Quote
Old 03-17-2021, 07:41 PM   #13
johnneilson
I’ll be over to pick it up
J
Old 03-18-2021, 05:12 AM   #14
Bruce of MN
Bruce of MN's Avatar
When I was reinstalling the head studs, one was a little loose, so I decided to helicoil it. Well, I didn't research it well enough and, afterwards, an experienced Model A’er had to remind me to use the head as a guide to drill the hole for the tap straight. My two helicoils were 4 deg from square and the head wouldn't go on. I removed them and used this insert to recover from my error: www.mcmaster.com/90259ai54. The specs say it needs a 33/64" tap drill, which I don't have, but 1/2" worked fine. In order to use the head as a guide, the holes in the head had to be reamed to 11/16" (as I recall), but that doesn't hurt anything, in my opinion. For checking squareness of tap, I used a 4" square I have. I would start the tap, turn enough to get a bite and then check for square in two directions, then adjust the tap and continue to bias the horizontal force in the direction needed and repeat every half turn or so. I used a nut and bolt to install the insert.
Old 05-01-2024, 08:37 PM   #15
31 Woody
31 Woody's Avatar
Thank you for the advice. I do appreciate it. My Dad has an engine that someone gave him that has the exact same issue. Somehow Dad was able to get the head on it, but one of the water neck studs is crooked. I am glad that I posted on FordBarn because there was a lot of good advice that I wasn’t even looking for.
Experience is a cruel teacher. It gives the exam first, then the lesson.
31 Woody is offline   Reply With Quote
