Old 01-25-2021, 08:23 PM   #1
brum1
brum1's Avatar
Default Ignition cylinder removal
In the process of replacing the original lock cylinder as it only had 1 key. I have removed from housing and it is not obvious how to remove the cylinder itself?
I have a replicate with 2 keys I want to install, any help is appreciated, I have attached a picture, thanks for the help!!
"no one knows more than everyone"
brum1 is offline   Reply With Quote
Old 01-25-2021, 08:37 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Ignition cylinder removal
I think I would take it to a good locksmith.
Old 01-25-2021, 09:39 PM   #3
jw hash
jw hash's Avatar
there is three mounting screw holes for the screws that holds the pop out in the dash panel. in one of them holes it has a spring loaded release that you can get to when the pop out is in the out position. simply put a ice pick in the hole and push it in. it will release the tumbler. note, it will only work if the pop out switch is in the on position.
jw hash is offline   Reply With Quote
Old 01-25-2021, 09:42 PM   #4
Brubaker
Brubaker's Avatar
Helpful? I could scan tomorrow if that helps. Bruce
Brubaker is offline   Reply With Quote
Old 01-26-2021, 06:58 AM   #5
brum1
brum1's Avatar
Thank guys, just what I needed to see,
Regards
Old 01-26-2021, 11:04 AM   #6
Bob C
Wouldn't it be easier to just get another key made or is the switch one
of those made in Spain with the weird key.
Old 01-26-2021, 05:18 PM   #7
McMimmcs
McMimmcs's Avatar
I think good sound advice !
Old 01-26-2021, 06:00 PM   #8
brum1
brum1's Avatar
unfortunately, I have been to two reputable lock smiths with the blanks sold from Model A vendors-they could not replicate, I believe the blank we just not correct for the key(#) I had
Old 01-26-2021, 06:08 PM   #9
Bob C
Did you try Dick Crabtree 605-487-7229, if anybody can fix you up he can.
Old 01-26-2021, 07:11 PM   #10
JayJay
I had this problem with my pickup. The ignition switch is a "popout" but likely not original, and the only key I had for it doesn't look anything like the blanks the vendors sell (slots on the wrong side). So I took it to my locksmith and he took it as a challenge. He found a blank that had the correct slot in it but was too long and too wide (I think it was originally a door key of some sort). He painstakingly ground away the parts he didn't need until he got a good fit on the blank, then cut the code and it works fine. I think he took it as a challenge. Same thing for the door, it wasn't a standard blank. He charged me $35 for both, which I think is very reasonable. I'm going to take the door cylinder from my Town Sedan to him to cut a key.
The Town Sedan ignition is not a popout so I know it isn't original. I'll be looking for one when I get to restoring it.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 01-26-2021, 11:27 PM   #11
Joop
Joop's Avatar
Looking at the picture Brum is posting he is using an aftermarket popout
Very hard for those to find a key.
Joop is offline   Reply With Quote
Old 01-27-2021, 07:19 PM   #12
brum1
brum1's Avatar
Yes, Joop that was my realization as well, I did end up buying my replacement for Dick Crabtree
