Old 01-26-2021, 12:16 PM   #1
Oldgearz
Default Engine Oil
Hate to start WWIII, but is PennGrade SAE 40 high zinc and phosphorus used by Aers very much?
Oldgearz is offline   Reply With Quote
Old 01-26-2021, 12:21 PM   #2
redmodelt
redmodelt's Avatar
Default Re: Engine Oil
Not by me. 10-30 or 10-40 depending on what time of year. Zinc is not needed in a Model A engine.
Old 01-26-2021, 01:13 PM   #3
Conaway2
Conaway2's Avatar
My engine rebuilder recommended Valvoline VR-1 high zinc racing oil, 10W-30. Given what I spent on the rebuild, I follow his recommendations.
Conaway2 is offline   Reply With Quote
Old 01-26-2021, 01:20 PM   #4
McMimmcs
McMimmcs's Avatar
Well stated, the perfect answer !
Old 01-26-2021, 03:10 PM   #5
GeneBob
The guys at the shop that rebuilt my engine specifically suggested higher zinc level oil. I use the Lucas "Hot Rod & Classic Oil". Good price and no concern about the high pressure sliding surfaces on tappets and gears. Maybe the Model A does not have high pressures on the tappets? I do not know but I wonder how good the cam profiles were 90 years ago. Today's modern oils actually limit the zinc to very low levels and today's engines are made for that.
GeneBob is offline   Reply With Quote
Old 01-26-2021, 04:51 PM   #6
J Franklin
J Franklin's Avatar
use a 10-30 or 10-40 that is all you need unless the engine is worn out. Zinc won't hurt anything.
Old 01-26-2021, 05:25 PM   #7
Y-Blockhead
Y-Blockhead's Avatar
Old 01-26-2021, 05:47 PM   #8
Ted Duke
use motor oil
Ted Duke is offline   Reply With Quote
Old 01-26-2021, 08:39 PM   #9
California Travieso
Send a message via Yahoo to California Travieso
Ted,
Did you mean “used” motor oil, like in the old days! ��
David Serrano
California Travieso is online now   Reply With Quote
Old 01-26-2021, 11:42 PM   #10
Jack Shaft
My father ran "drain oil" in his coupe..he would buy it for a penny a quart, oil drained out of the cars the local gas station serviced..
Old 01-27-2021, 12:13 AM   #11
J Franklin
J Franklin's Avatar
Most stations used a service where the old oil was re-refined and re-sold as reclaimed oil. I doubt he ran dirty oil, there would be no good doing so.
Old 01-27-2021, 01:19 AM   #12
Jack Shaft
Thats nice,you doubt a story told to me by my father..take a minute,think about that..
Old 01-27-2021, 02:14 AM   #13
J Franklin
J Franklin's Avatar
I just think he was buying reclaimed oil (drain oil that is re-refined) and called it what he did. Think about it. Why change oil if you are just putting dirty oil back in?
Old 01-27-2021, 02:15 AM   #14
McMimmcs
McMimmcs's Avatar
Your story is very authentic and was repeated over and over. My father owned a service station and was part of that process.
Old 01-27-2021, 08:19 AM   #15
McMimmcs
McMimmcs's Avatar
They were not changing oil, they were adding a quart to stop the engine from seizing up. Times were tough, think about it !
Old 01-27-2021, 08:45 AM   #16
Bob Bidonde
Bob Bidonde's Avatar
Many moons ago when I pumped gasoline, the station owner had a 275 gallon oil tank in a back room. It contained the residual oil that dripped from every can of oil used at the station. The oil from that tank was sold as "bottle oil" at a lower price than the canned oil. This practice was common place back in the 1950s and 1960s. In my garage these days, I continue this practice of draining residual oil from containers.
Bob Bidonde
Old 01-27-2021, 09:51 AM   #17
runewilliam_merc
There is a product called oil saver:
Rune from Norway
Sent fra min S52 via Tapatalk
runewilliam_merc is offline   Reply With Quote
Old 01-27-2021, 10:02 AM   #18
1929
My builder recommended Valvoline Racing oil 20W-50.
1929 is offline   Reply With Quote
Old 01-27-2021, 10:58 AM   #19
katy
katy's Avatar
Back, before they put detergents in the oil, a lot of people put used oil aside and let it sit for a few weeks. All or most of the contaminants would settle out and "clean" oil could be scooped out for re-use.
Bindar Dundat
Old 01-27-2021, 11:21 AM   #20
redmodelt
redmodelt's Avatar
The guy I worked with does somewhat the same thing. He drains the oil from each container into his oil cans. When adding fresh oil to an engine, I let each one drain for a while before adding the next one.
