hello
i may have a clogged vent hole in the shift tower. how do you check it and clean it? do you have to pull the shifter to clean it? thank you kevin |
Just stick a piece of wire thru it.
Use a small drill bit and turn by hand
thanks
kevin |
If totally plugged a slowly hand turned drill bit and a source of vacuum to catch the debris.
