Old 01-04-2021, 09:11 PM   #1
phil pavicich
Default 40 ford rear hub sleeves
I Have just pulled down some old stock 40 rear hubs and the outer dia of the hub has lots of pitting ,(water /rust damage from sitting a long time ) is this a sleeve inside there or is it original machined hub surface , Is there a sleeve available to press in and fit smaller od bearings ? or am i up for new hubs
Thanks In advance Phil
phil pavicich is offline   Reply With Quote
Old 01-04-2021, 10:39 PM   #2
mercman from oz
mercman from oz's Avatar
Default Re: 40 ford rear hub sleeves
Sorry, Can't advise you of what to do, but here is a larger picture so other Ford Barners can see the problem easier and offer suggestions.
Old 01-04-2021, 10:50 PM   #3
Newc
Newc's Avatar
Well, Does the brake diameter make it worth saving? Nice taper and keyway? Newc
Old 01-04-2021, 11:19 PM   #4
Brian
Brian's Avatar
Are you sure that's a 40 hub? I thought all hubs 36-48 ran a sleeve 68-1236A with the 68-1225A roller bearing, which is smaller in dia than the earlier style B-1225A roller bearing 28-36, which ran directly in the hub. That hub looks like it's had rollers running directly in it as evidenced by the pattern left in the rust.
Old 01-05-2021, 03:01 AM   #5
phil pavicich
Yes its definitely a 40 hub , the sleeve 68-1236A 3.120" OD is for a 34 hub ,this sleeve presses into a 34 hub and then you use the 68-1225A roller bearing , this sleeve is to big in diameter to go inside my 40 hub which measures 2.840" OD , yes this bearing runs directly on the hub surface , Ive tried a few suppliers in Australia but they only carry the sleeves for the earlier hubs , i will probably buy new replacement hubs and use my l standard size drums
