Looking for an F-100 steering box conversion for a 28/29 sedan.
I know there was fellow in Calif. that was selling those but not sure whether he is still doing that. Thanks for any help. Charles |
Yes he is. His name is Randy Gross you will find him in the Swap meet section, he lists brake drums and shoes and also F-100 steering. A good guy to work with.
Randy
714 292 8660
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? ![]() |
Randy Gross is a true professional and guarantees satisfaction. Very experienced and helpful.
I put Randy's brakes ND STEERING ON MY 28 GOOD GUY TO WORK WITH
Thanks for the get back on Randy Gross.
Sorry so long in getting back. Been out of town out of town . |
I had Randy do my brakes and he was great to deal with. he took the time to explain what needed to done and my brakes work flawlessly. I would definitely use him for a steering upgrade.
I tried one and did not like it. I rebuilt my original and used a shortened pitman arm.
John
Welcome each day |
I'm not knocking Randy Gross and I'm sure the up dated steering gear he builds is first rate. However, if you rebuild your original (2-tooth or 7-tooth)
steering gear correctly. It will be just fine, maybe not as smooth & easy as your new auto. But, heck it is a 90 year old car! I'm the first person to admit that I am no mechanic. Yet, I have rebuilt one 7-tooth and two 2-tooth "A" steering gears and they all turned out good. Take your time and always use new bearings ,bushings, sector shafts and worm gears. I also use the shortened pit-man arms. Good luck. ![]() Bob-A ![]() PS: Never try and turn your steering wheel without the car moving or the front end jacked up. It is very hard on your steering gear. ![]() |
The more senior of us find the Model A's steering to be hard on our arms and shoulders. So there is a need to make the steering easier.
Bob Bidonde |
#13 |
The F100 boxes use the roller sector shaft like mid 30's -on vehicles. Easier to steer but sometimes difficult to adjust out the free play. Btw, a shortened pitman arm on a stock gear most often needs an adjustable drag link (see other threads) to adjust for zero freeplay at the gear centered and wheels straight ahead.
#14 |
#15 |
#16 |
FYI
I sent a PM to John in Illinois and offered to refund his money upon the return of the box if he bought it from us. We strive on making sure all who buy from us are satisfied. Randy Gross 714-292-8660 [email protected] |
#17 |
Super Service Randy.
I have 2 and love them. |
#18 |
I did not get it from Randy. I know he does good work. I simply did not like it as well as the original box.
Welcome each day |
#19 |
#20 |
Hats off to Randy. A true example of a great vendor.
He didn't even question how long he had it. I purchased brake drums, shoes, a hub, bearings etc from Randy. Everything was fine. |
